United Radio
Old 10-23-2012, 09:21 AM
thebaldguy's Avatar
thebaldguy thebaldguy is offline
Vehicle: 2012 Dodge Ram
Trim Level: Big Horn Crew
thebaldguy is on a distinguished road
Default Air Lift 1000 Kit
I’m thinking about purchasing an Air Lift 1000 kit to level out my 1500 when hauling a trailer. I have the upgraded suspension from the factory but want to make sure the back end doesn’t sag. Has anyone purchased these? How was the install? Did you have to remove the spring to insert the bag?
Thanks!
Old 10-23-2012, 09:45 AM
Vehicle: 2012 Dodge Ram CC 4X4
Color: PX8 Black
Thanks!
Upgraded suspension? Can you explain this a little more?
But many have purchased this exact kit on the forums.
I have a lifted truck and will be purchasing these too.
Install is quite easy as many have explained. I haven't done it yet. But again, many say it is quite easy.
The coil does not need to be removed.
Simply heat up the bag and roll it into a hotdog and slide it into the coil.
Some have even Tee'd off the line to run different PSI on either side of the bag
Hope this helps somewhat
2014 Ram Hemi Tuning now available from Diablo Sport get yours today!
Old 10-23-2012, 11:07 AM
thebaldguy's Avatar
When I purchased the truck I got the “tow package”. This package has the transmission cooler and brake control on it. The sales person said it has the upgraded suspension. Not exactly sure what that is or if there is such a thing from the factory. Sales guy might have just pulled it out of his …
Thanks for the response. I will be ordering the kit today.
Old 10-23-2012, 11:35 AM
Color: PX8 Black
Maybe someone else can chime in, but from my knowledge there is no 'upgraded suspension'
I believe its simply the transmission cooler and brake control unit among small outer things.
But it does work with the rams, that I know
Old 10-23-2012, 12:24 PM
X231 X231 is offline
Rep:16
X231 is on a distinguished road
baldguy get back to us and let us know what it cost you, how was the install, and if you like the airlift kit. I'm in the same boat and have to make up my mind in the next 3 weeks. I like the TLC kit but don't know if I can justify the expense for just a time or three a year of use.
Old 10-23-2012, 12:31 PM
Color: PX8 Black
The cost of this kit is $85-$90 for the complete kit (minus a compressor).
Just an FYI
Old 10-23-2012, 12:47 PM
Trim Level: sport
Color: green
Rep:632
i was also told when looking t an outdoorsman had an upgraded suspension, when i pressed for info, and pointed out tongue weights ect... salesman kind of back off and said he would have to find out.
Old 10-23-2012, 12:50 PM
Color: PX8 Black
I think from front struts are different as I know the Outdoorsman are taller by an inch or so.
But I think the rears are the same....but again, I could be wrong
Old 10-23-2012, 12:52 PM
Rep:16
Just an FYI
Thanks for that info fNu .. that doesn't sound right does it? lol
You're right on the price. I had them on a Ford and seems I paid closer to $150, so $85 sounds good especially vs $400 for the TLC. Now I just have to figure out what I'm going to do about leveling the front
Old 10-23-2012, 12:56 PM
Color: PX8 Black
Yea, doesnt sound right, but that is the short of it
Level you say....easy.
You can do level spacers. Hell Bent Steel makes some 2" and 2.5" level spacers for sub $100 (there are others as well, such as Ready Lift, etc)
But if you want an improve ride and willing to spend a bit more, I would do the Bilstein 5100 and you have level increments of 0", 0.7", 1.4" 2.1" and 2.75"
But you will notice a ride improvement over stock and you get a nice level
