Old 10-01-2012, 03:18 PM
BigRed23 BigRed23 is offline
Vehicle: 1995 Dodge Ram 2500
BigRed23 is on a distinguished road
Default 360 to 318 engine swap
I have recently swapped out a blown 360 in my 95 dodge ram 2500 for a 318 in good working order. The 318 is out of a 97 1500. It ran well at first, but now it is having idle problems. I am running the 318 off the old ECU from the 360. Is that causing the problem? I am getting a loud hiss from the IAC. When After it warms up the idle drops to below 500 rpm momentarily then kicks back up to 1500 and repeats. I have tried adjusting the minimum air to the throttle body with the result being idle at 3000 rpm! I have replaced the IAC, PCV, breather element, and throttle body gasket. Any input would be greatly appreciated!
Old 10-02-2012, 10:42 PM
moparornocar72's Avatar
Rep:630
Sounds like something maybe leaking
14.268 @ 95 MPH Full Trim
Old 10-04-2012, 10:32 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Yeah, sounds like a decent sized vacuum leak.
318, 360, ecu, idle, swap
