United Radio
Old 09-20-2012, 12:47 AM
bfsoper's Avatar
bfsoper bfsoper is offline
Vehicle: 1997 Dodge Ram
Color: rhino lined black & custom green
bfsoper is on a distinguished road
Question Any luck wih the gforce performance chip?
hey guys i was lookin @ the GForce performance chip heres a link http://www.gfchips.com/dodgeram1500.aspx i was wonderin if any1 has it & has had any luck with it or if its just a waste of money. I figure for $69 its worth the try, with the 100% no questions asked refund, whats the harm in trying? anyway, im hoping some1 HAS tried it so @ least im not shootin in the dark. thx guys!
BIGGER, better, LOUDER, ShWeEeEeEeT!!!
Old 10-02-2012, 11:09 AM
jprevette's Avatar
jprevette jprevette is offline
Vehicle: 1996 dodge ram 1500
jprevette is on a distinguished road
i have it and it works the only bad ive seen so far is no mpg gain but i do notice a large difference in power. i have beaten a hemi ram and a 2012 Nissan titan
its just a little 318..... o yea bye bye
Old 10-02-2012, 11:12 AM
jprevette's Avatar
also its not really a "chip" it steals the signal from the IAT and reads lean to the computer to gain more more power the harder you hit it the more it does
Old 10-02-2012, 01:51 PM
Rep:1845
I'm calling bullshit on this. IAT is a small part of a large fuel equation where MAP and O2 values are the primary determining factors for the fuel curve. Simply lying to the PCM with IAT values will not significantly effect the curve. Think about it - what happens when you dump more fuel into the cylinder? You get less oxygen in the exhaust stream, right? The O2 sensor sees this and passes it along to the PCM where the fuel curve is adjusted to maintain the 14.7:1 stochiometric air-fuel ratio. Basically what will happen is that the PCM will adjust the long term fuel trims to compensate for the false input. You can go to Radio Shack and buy a twenty-five cent resistor that will do the same thing.
Old 10-02-2012, 01:55 PM
Rep:1845
Air in the intake isn't rich or lean so the IAT doesn't actually "read lean". It reports air temperature in the intake to the PCM.
Old 10-02-2012, 04:28 PM
ShiftJockey's Avatar
ShiftJockey ShiftJockey is offline
Vehicle: 2007 Ram 1500
Color: Gray
Rep:48
ShiftJockey is on a distinguished road
^^^^ He's Right ^^^^ there is a lot more to it than just that.
Watch out for these "chips" that send false signals to the sensors and PCM. They can overfuel your engine and cause some damage to combustion components, O2 sensors & catalytic converters as a result.
Upgrading one part at a time.
Old 10-03-2012, 12:08 PM
jprevette's Avatar
well all i can say is it works and ive gotn it dynoed to prove it
Old 10-04-2012, 10:52 AM
Rep:1845
I look forward to seeing the before and after dyno pulls when you post them.
Anyway, lets examine the fuel calculation:
RPM/Max RPM x MPA/Baro x EGR flow (if applicable) x TPS x ECT x IAT x Sensed B+ x Upstream O2 x ST fuel x LT fuel x Purge Vapor Ratio = Pulse Width
From this, it's easy to see that IAT fuel modifier is only a small part of the overall calculation and to claim a 60 HP gain is just plain ridiculous.
Old 10-04-2012, 05:57 PM
jprevette's Avatar
http://thumbp10-gq1.thumb.mail.yahoo...=480&httperr=1
jprevette's Avatar
i hope that worked. also i don't have a before and the chip isn't all i have
ecu, gforce, performance, power, tuning
