Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 8.0 Liter V10
Custom Dodge Ram Performance Mods - Engine - 8.0 Liter V10 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 10-23-2012, 09:40 AM
BigClay BigClay is offline
Vehicle: 1996 2500 V10
Rep:19
BigClay is on a distinguished road
Originally Posted by ramvan2500 View Post
Where was the crack? And do you want the old block? Also as far as a cam, even comp has a limited selection in cams for the V10 magnum. Personally the V8 5.2L magnum can make about 505 naturally aspirated horse power in addition to 478 ft-lbs of torque. So if more companies invested in performance parts for the V10 magnum, imagine what kind of torque you could expect.
The crack was right at the starter/bellhousing. I used the old block to get the new block.
I wish there was more support for the V10, it would be amazing what could be pulled from having two extra cylinders.
1996 extended cab, long bed, with a freshly rebuilt V10
Old 10-24-2012, 05:08 PM
AJ@AutoAnything.com AJ@AutoAnything.com is offline
Vehicle: Full Garage!
Trim Level: ....
Rep:48
AJ@AutoAnything.com is on a distinguished road
Is the motor back in? It sounds like the list that you shared should get you to where you want to be. Unfortunately there is just not a lot for these motors, have you though about cooling since you tow a lot?
-AJ
Click the ^banner^ and save up to 16% on Dodge Ram mods.
We price match, simply call 888-591-8563 or
Click-to-liveChat and we'll beat ANY price by $1.
Need a Tonneau cover? Research guide here.
Old 10-25-2012, 09:27 AM
Rep:19
The motor is not back in yet. Still waiting on the right springs and a few bolts, but hopefully those will be delivered today and so the motor can be finished up. Hoping to have the truck on the road next week.
Old 02-15-2013, 11:47 PM
v10gearhead v10gearhead is offline
Vehicle: 2002 Dodge ram 2500 V10
Engine: 2003-2003 488ci (8.0L) Magnum V10 310hp 450lb/ft
v10gearhead is on a distinguished road
From what I understand the V10 is running at 450 foot pounds torque, and if your running the 47RE automatic transmission, its rated at the same 450 lbs torque. If you are then DDT has transmission upgrade kits http://www.dttdiesel.com/product-p/d...ebuild-kit.htm you may want to look at that if your going to be pulling more power out of that engine. and Fastman makes a throttle body too http://www.thefastman.com/throttlebodies80.php I hope this helps some.
good luck.
Tom
Old 03-05-2013, 08:17 PM
jljplumber jljplumber is offline
Vehicle: 94 dodge ram
jljplumber is on a distinguished road
ram air hood...I am going with that
Old 03-07-2013, 09:25 AM
Rep:19
I ended up putting headers on the motor, a good port, polish, and matching. Everything else I left stock. I have the NV4500, so I think planting the powere is not a problem.
Old 07-31-2013, 05:22 PM
Dieselgod20 Dieselgod20 is offline
Vehicle: 1994 Dodge Ram 2500 SLT
Trim Level: Slt
Color: Patriot blue
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
Dieselgod20 is on a distinguished road
Default Don't be discouraged,
There are a lot more options than u know about with that v10. I built mine as a pulling truck motor, I was able to bore it .060, pistons from Ross racing pistons, H beam rods from lunati, a custom ground cam from crower, a viper forged steal crank, ARP head studs, all new felpro gaskets, ported the head and shaved it .050 for a 12.0:1 compression, and it is now a 519ci 675hp monster, don't be doubtful, just do the reseArch
Old 07-31-2013, 07:37 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
I did the research, but in comparison to the 360/318 Chry, or 350 Chev... No comparison at all, more bolt on parts available to those then just about anything else. I'm surprised you were able to run a 12:1 compression on cast iron heads, but then again what was the IVC on the cam? DCR vs SCR...
Old 07-31-2013, 10:43 PM
Trim Level: Slt
Color: Patriot blue
Well coroner had to take a viper cam and grind it to my specs with a 685 lift, and I can do it with cast iron heads with head studs and I use copper head gaskets, due to u can get different thicknesses for valve clearance
Old 07-31-2013, 10:46 PM
ramvan2500's Avatar
Rep:128
Yes but valve clearance also depends on valve even times. If you do a little trigonometry you can figure out exactly your valve clearances at different degrees of crank angle. I was just thinking what your IVC time must be, for 12:1 SCR (assuming SCR) then you must be something close to 70 degrees ABDC... that or you are running higher octane fuel and a cool thermostat
