Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 > MDS
MDS Multi Displacement System Discussion
Old 09-13-2012, 03:56 AM
Captain Cooter Captain Cooter is offline
Vehicle: 2012 Ram Sport Reg Cab 4x4
Color: Flamin red
Captain Cooter is on a distinguished road
Default MDS Lifter Delete
Anybody know if this is a sure-fire way to disable MDS? Since we cannot flash the ECU this makes perfect sense. My only concern is if it triggers a DTC and won't pass emissions. I'm considering a mild cam and saw the lifter deletes. I may shoot them an email and ask, just thought I'd run it by yall.
http://inertiamotorsports.com/camshafts.html
Old 09-13-2012, 08:06 AM
I push the skinny pedal
Rep:3277
It's a 100% fix if you want to delete it. It's the same non-collapsible lifters that are in your other 4 cylinders. I can't guarantee that you won't their a code since everyone I know that has done it has tuned their vehicle and disabled it.
Kurtis
Old 11-07-2013, 09:06 PM
dbuzz77's Avatar
dbuzz77 dbuzz77 is offline
Vehicle: 2009 Ram RCSB 4x4
Color: Stone White
Rep:100
dbuzz77 will become famous soon enoughdbuzz77 will become famous soon enough
i believe programmers can turn it off if you are using one
2009 RCSB Sport, SC Cortex, K&N air box, all Amsoil fluids, Fan delete, Grounded TB, homemade catch can, homemade gps mount, Fastman TB, EZ down tailgate, Bully hitch step
Then God made a hemi, and knew that it was good.
Old 11-07-2013, 09:13 PM
Rep:3277
Correct, but at a certain cam lift you can collapse the lifters, which is why there is a delete kit available. The only way to handle this is to physically remove the collapsible lifters.
Kurtis
Old 11-07-2013, 09:28 PM
Rep:2640
The MDS Camshaft is also ground differently
My thought is, the 1500 MDS engine that uses 5w-20 & the 2500 NON MDS engine that uses 10w-30 blocks are the same engine
it is the camshaft & lifters that are different
the rest of the sensors & stuff could be left off of the 1500 engine & it would not mess with passing smog tests, because they are testing the smog of a working 8 cylinder engine, not a engine that is running on 4 cylinders
MDS i don't believe has anything to do with smog, it was only done to pass the Federal Government's CAFE Mandates
EDIT:
the question would have to be, will the check engine light come on, if it does, it won't pass smog
Old 02-05-2014, 08:21 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
Easiest and cheapest is just put it in "6". When its cold I automatically bump into "6" to make more engine heat faster, I don't even think about it anymore, its habit.
Any more for in town I just hit "tow/haul", again habit.
2014 Express 3.6/8 speed/3.55 gears...Work Truck
2012 Equinox 2.4...Wife's Ride
"Life's hard, it's harder if your stupid."
How would you know?
Old 02-13-2014, 08:37 PM
roo roo is offline
Vehicle: 2013Express,2014 Charger R/T
Rep:44
roo is on a distinguished road
That's exactly what I do, funny my Tradesman with the single exhaust is much more obnoxious when MDS kicks in than my Express.
Old 02-14-2014, 12:50 PM
rdsabin rdsabin is offline
Vehicle: 2012 Sport Reg Cab 4x4
Trim Level: Sport Reg Cab
Color: Mineral Gray Metallic
Rep:186
rdsabin has a spectacular aura aboutrdsabin has a spectacular aura about
I use the DCX 1000 programmer from Diablo to turn off MDS. Prior to getting the programmer I did what the others stated which is to shift to 6 or put the vehicle in Tow/Haul mode. Both of these work fine, however I am very pleased with the programmer as you do not have to mess with pushing any buttons once you set it to turn off MDS.
2012 DodgeRam 1500 4x4, 20% Tint, Running Boards, Class IV Hitch, 14" Win Muffler, Catch-Can, Tow-Hooks, LED Tailgate Bar
2008 Dodge Supe Bee, Catch Can, Backup Camera, 20% Tint all windows, CAI, AFE Filter
