Old 09-11-2012, 10:39 AM
Originally Posted by EODtruck View Post
Dealer said I would need 1.5" spacer!! I said screw it and just went with the stock size Dueler AT Revo 2's, which weren't cheap either, lol. They said the spacers would void some warranty work.
Spacers voiding warranty work?
I think that is BS but each dealer does their own thing
click here --->***Tuner and Muffler Sale*** <---click here
Old 09-12-2012, 04:00 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
Sweet!
Im guessing you are not getting any shakes or vibration?
I prefer the bolt on wheel adapter over spacers...
I don't have them anymore, but I never had any vibrations or shakes. As long as you get hub centric spacers you should be fine. You could even go one step further and get hub rings to match the wheel bore to the lip on the spacer(all the spacers ive used have had a lip on them for the wheel to sit on, just like the hub itself).
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Thuren | Carli
Old 09-12-2012, 10:43 AM
Sweet!
Good info....many fear spacers....I too but if I did this, I would do wheel adapters like what you have
Old 10-18-2013, 09:27 PM
hemipowerv8 hemipowerv8 is offline
Vehicle: 2013 Ram Sport CC 4x4
Rep:74
hemipowerv8 will become famous soon enough
Pulling this old thread up... So I'm running 35x12.50 on stock 20s with 2.1" Bilstein level and 10mm hub and wheel centric custom spacers. Driving my truck more than anticipated and thinking when I'm due for rubber I may drop a tire size.
Being that a 12.5" tire is about a 315 and a 10mm (1/3 inch) spacer does fine...if I drop just a bit to a 295/60 (34x11.7 is .75" thinner) then I should have the same clearance as I currently do but without the spacers?
Effectively tucking the tires underneath 10mm and another 10mm slimmer per side (tire is total 20mm thinner).
Anyone successfully running a 295/60R20 (Nitto or Toyo all terrain) with no wheel spacer on stock sport wheels?
Mods: Tint, Line-X spray in, PD emblems, Weathertech mats, Honeycomb grille, Mopar tow hooks, Magnaflow 18" and Y, Bilstein 5100s @ 2.1" & TGC rear spacer .75", Toyo All terrains 35x12.50x20, 5" black tips, BakFlip tonneau cover, 87mm tb
Next: Gorilla lifetime lug nuts, CAI, Diablo tune.
Old 10-19-2013, 12:04 AM
This is correct. You'd be able to run that size without spacers.
Its close.... But it fits
