Old 11-10-2012, 11:20 AM
ssxrnr ssxrnr is offline
Vehicle: 2012 Dodge Ram
Trim Level: R/T
ssxrnr is on a distinguished road
How do you dial in 1.5* negative Pinion Angle?
Old 11-10-2012, 11:48 AM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
Shorten the upper bars to tilt the front of the diff down...use a degree finder to set it off the pinion.
Old 11-23-2012, 01:38 PM
Trim Level: R/T
In a previous post you mentioned KYB shocks as an alternative to the QA1s.
I have the Ground Force lowering kit that comes with front/rear springs and new rear shocks. Would you recommend adding the KYB Gas Adjusts fronts shocks as well. I am not sure spending additional $650 to put 4 QA1s is worth the $$ or add the QA1s to the front is still $300 vs $100???
Old 03-01-2013, 02:55 AM
TriSum's Avatar
TriSum TriSum is offline
Trim Level: R/T
Rep:47
TriSum is on a distinguished road
Unbroken, had / have you ridden in any other lowered 4th gens with different shocks to compare them to the QA1's? I'm trying to decide if I should get the QA1's or the BT Kit w/ shocks included. Just curious if you actually compared them or if you just really like them?
Thanks,
David
2012 R/T
ARH Longtubes, Diablo Trinity, Flowmaster, Belltech 2"/4" Lowering Kit, Spohn Track Bar, Bak Flip "VP" Tonneau Cover, Oil Catch Can
Old 04-21-2013, 12:09 AM
BATRAM88 BATRAM88 is offline
Vehicle: 2012 Dodge ram
Trim Level: SLT Lonestar
BATRAM88 is on a distinguished road
Anybody have the part number to the QA1's UNBROKEN used?? Really wanting to throw these on my truck. Sooner the better.....
Old 04-21-2013, 11:54 PM
db1 db1 is offline
Vehicle: 2010 dodge ram
Trim Level: sport
Color: mineral grey
db1 is on a distinguished road
looks awesome . gunmetal rims the way to go!!
DOSNT ROLE ON TEENAGE RIMS!
Volant cai , bt catch can,180 stat, Moes 85mm, Sonnex line booster, Superchip programmer Tranny upgrade , Bilstein shocks 25% stiffer springs, Air bags, 22" srt10 replicas matt black, magnaflow tru x muffler.
Old 04-22-2013, 02:07 PM
blackedout12's Avatar
blackedout12 blackedout12 is offline
Rep:19
blackedout12 is on a distinguished road
I have read this post from front to back and have learned more in the last 10 minutes on lowering a truck then ever. UNBROKEN is a highly intelegent man. He really broke down everything that we normaly people who are not in the business understand better. I have been looking into some new shocks after the MCG 2/4 kit and I like the QA1's that were mentioned since you fine tune them. I will be ordering shorlty and will post the PART # needed. Great Build/Great Truck
McG 2/4, Smoked Tails/3rd, Tonneau Pro Tri-Fold, Debadged, Paint Matched Interior, FlowMaster Exhaust, LED Brake Light Bar, K/N Drop-In
Mods from Bully Performance:
AirLift 1000's, Jet T-Stat 180*, Vararram-T1000-Future Mods--Ordered
Old 05-12-2013, 11:54 PM
Wilson281's Avatar
Wilson281 Wilson281 is offline
Vehicle: 2013
Trim Level: Regular Cab Express
Rep:15
Wilson281 is on a distinguished road
Hey bro where in Houston are you?
Old 05-19-2013, 01:00 AM
ValleyRacer ValleyRacer is offline
Vehicle: 2013 Ram RT
Trim Level: RT
Color: Steel Blue Metallic
Rep:136
ValleyRacer will become famous soon enoughValleyRacer will become famous soon enough
Default Very impressive
Originally Posted by UNBROKEN View Post
Truck had 632 miles on it when I pulled into the shop this morning to work on it. I added the gunmetal SRT10 wheels and Pirelli Scorpion Zero tires yesterday.
Here's the parts list:
McGaughys 2/4 spring kit.
Spohn link bars and adjustable panhard bar.
Hellwig front and rear sway bars.
QA1 adjustable shocks.
I adjusted the McGaughys kit...took 1/2 a coil off the front and a full coil off the back shooting for a 3/5 or close. I'll measure tomorrow and see where it settled to but the back is right at an inch higher than the front which is just what I hoped for. McGaughys doesn't include front bump stops so I grabbed some urethane button style stops and removed the cup up front and they bolted right into place. The button stops they include leave at least 4" of travel in the back, more than I expected but a nice surprise anyway. I painted the frame everywhere I cut a spring cup off with semi-gloss black...matched perfectly.
The Hellwig bars were a breeze, less than 5 minutes to install them with an impact doing the work.
The rear upper shock bolt isn't nearly as bad as people say...pop the fender liners off and they're staring right at you. A 1/4" drive air ratchet is your friend here for sure.
The only parts that gave me issues were the Spohn stuff. The steel sleeves in the bushings were too small ID for the bolts to fit through. I had to press them all out and machine the holes bigger in a lathe. I'll be sending them an email to let them know about it so nobody hits that snag in the future.
The QA1's....wow....money well spent. I've already made a few adjustments and I think another notch or 2 softer and it'll be perfect.
You get what you pay for with shocks...I've used Bell Tech shocks before....there is no comparison to these.
I only got one pic...it was flooding here all day and I grabbed a quick one outside the alignment shop. Speaking of that...I'm gonna take it somewhere else and let them work on the caster....it's still a couple of degrees out. Camber was -0.1 on both sides and toe obviously set back perfect. It's closer than I thought it would be considering I cut an already shorter spring.
More pics tomorrow of all the parts installed...this is it for today.
That is an impressive collection of suspension parts. More pictures would be most useful.
Old 02-02-2014, 05:11 AM
okcrt okcrt is offline
Vehicle: 2014 Ram R/T
Rep:42
okcrt is on a distinguished road
Default How should I?
I have the Belltech Street Performance suspension on my 2014 R/T. It's the 2-4, but I want to go lower. Can I cut a coil or so? and everything will be fine? Should I not cut them? Help me out please! Thanks!
