Old 08-28-2012, 10:31 PM
Stonednloaded Stonednloaded is offline
Rep:14
Stonednloaded is on a distinguished road
Default no license plate lights?
i put led bulbs in my license plate lights and now they dont work replaced with stock bulbs still nothing? any ideas
Old 08-29-2012, 06:44 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
I'd make sure that the fuse has not blown. If the fuse is good, I'd check for power at the bulb location using a meter or test light.
good luck
Exco
Bill
Old 08-29-2012, 08:23 AM
Rec 26's Avatar
Rec 26 Rec 26 is offline
Location: El Paso, TX via Centereach, NY, Vieques, PR, and San Antonio, TX
Vehicle: 2014 RAM 3500 Crew Cab Dually
Trim Level: Tradesman
Color: Bright White Clear Coat
Rep:71
Rec 26 will become famous soon enough
Send a message via AIM to Rec 26 Send a message via MSN to Rec 26 Send a message via Yahoo to Rec 26
Did it happen before or after you installed the LED? That LED could of blown your fuse if that is in fact the issue. Best bet will to go with a larger fuse.. Mind me asking where you got the LED?
2011 Ram 1500 Big Horn Quad Cab "SRT Hauler Mark I" (traded in)
2014 RAM 3500 Tradesman Crew Cab "SRT Hauler Mark III"
Old 08-29-2012, 12:58 PM
Rep:14
got them from e bay...where is the fuse location exactly for those lights
