Old 08-28-2012, 12:00 AM
Piemei Piemei is offline
Vehicle: 2008 Dodge Ram
Color: silver
Piemei is on a distinguished road
Default trying to find a pigtail
Hi there, i'm jeff and i'm trying to find a pigtail with this end on it. i've just bought a new set of headlights, and i'm trying to modify my headlights. I want to add LEDs and load resistors without messing up the original wiring too much in case i have to get rid of the new headlights for any reason. any ideas? i've hunted around but i dont really know what to search for or where to look! any help would be appreciated!
Old 08-28-2012, 12:18 AM
moparornocar72's Avatar
Rep:630
Should be able to look for the headlight wiring harness or relay, at the very worst I would go to a junkyard, couldn't be more than $5.
14.268 @ 95 MPH Full Trim
Old 08-28-2012, 12:21 AM
Color: silver
well the problem is, is this little pigtail replaces the actual socket, that came off my aftermarket LED tail lights. so its not an oem thing, which is why i'm having a hard time finding one. i bet the female side is pretty easy to find, but finding a male one would be much more difficult.
Old 08-29-2012, 07:54 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
looking at the pic it looks like it's just a couple of spade type connectors, surrounded by rubber. You should be able to make up your own pig tail, especially if you're having issues finding what you need. I agree it'll most likely be a PITA, but it might be better than not having what you want...
some (water proof) spade connectors, shrink wrap, and a few tie wraps and you should be good to go after a little bit of hair pulling and dirty word shouting
Exco
Bill
