Old 08-16-2012, 10:45 AM
Exxzaust's Avatar
Exxzaust Exxzaust is offline
Vehicle: 2012 Ram 1500
Rep:24
Exxzaust is on a distinguished road
Default Oracle Halo Rings
So I purchased my oracle demon eye set, just a couple quick questions.
I was just reading from one of the other ram members that silicone works better than epoxy for sticking the light to the lens? I got the CCFM one which is a glass tube light.
I want to wire it to it to the park light, so I read that pyro said theres 3 wires in the amber turn signal bulb, ground which both sides will be the same, parking light which both sides will be the same and then 2 diffrent colour blinker wires, true?
Anyone have any advice with baking headlights to remove and put them back together????? First time and going to be nerveracking! Thanks guys for reading
Dont be scared of the dark! Shine some light on it
Old 08-16-2012, 12:20 PM
Detroit3000's Avatar
Detroit3000 Detroit3000 is offline
Vehicle: 2009
Trim Level: Big horn
Color: Brilliant Black Crystal Pearlcoat
Rep:68
Detroit3000 will become famous soon enough
I've been wanting to do this to my 08 also. I'm waiting to track down a second set of head lights cheap (locally) before I order the oracles. Please update this thead with your progress as I am eager to see how the install goes. And pics to if you can!!!!
Old 08-16-2012, 12:34 PM
Exxzaust's Avatar
Rep:24
I'll take pictures and upload! Be this weekend or next weekend depending on when they come in and how soon people can help out with the questions
Old 08-16-2012, 12:48 PM
Vehicle: 2009
Rep:68
Not sure if you watched it or not but there is a short video on YouTube on the installation process. It's not very indepth. But I do believe the oracle kit comes with rather detailed written and video instructions. Hopefully people that have done the install will che in.....
Old 08-16-2012, 01:12 PM
Exxzaust's Avatar
Rep:24
Yes I did, got the general idea! See when it comes in and hopefully it's detailed instructions
Old 08-16-2012, 04:15 PM
Pyroboy5000's Avatar
Pyroboy5000 Pyroboy5000 is offline
Trim Level: TRX
Rep:37
Pyroboy5000 is on a distinguished road
sounds good man. glad to help. keep us posted.
I'm back from the dead!
R.I.P Old Blue 2013
Old 08-16-2012, 05:41 PM
gotbrains230's Avatar
Vehicle: '12 RAM 1500
Rep:420
yes you will have 3 wires. It is a dual filament bulb. ground, and two hots. One hot will be steady on (park light) and other other will be intermediate (blinker)...you use a meter or test light and figure out which one if the blinker wire. Leave your headlights off and turn the blinker on, just the blinker, or do it vise versa it doesnt matter. then just spice the halos into the blinker wire.
Tips on baking headlights apart
Go to home depot or somewhere and get a heat gun if you dont already have one
I tried the oven but it takes too long and cools too quickly...use the heat gun to get the silicone hot but NOT ENOUGH TO MELT THE LENSE (this comes from experience LOL)...then use a flathead screwdriver and pry up on the plastic...try to make nice clean straight prys on the plastic as it will be much easier to get it back together. Your best best is to pry up on the corners first and work your way around
MATT
Old 08-16-2012, 06:29 PM
Exxzaust's Avatar
Rep:24
You are a lifesaver! Thanks for the input! Should I put a small silicone bead on after just INCASE it didn't seal properly? I want to tap them to the park light but any chance I can also get them to blink when turning? Dont think do cause a constant hot wont be interrupted
Old 08-17-2012, 03:02 PM
Trim Level: TRX
Rep:37
remember, if he splices into the blinker wire that the halos will be blinking and only when hes turning! go with the parking lights and youll have the effect you want.
R.I.P Old Blue 2013
Old 08-17-2012, 03:05 PM
sullivan's Avatar
sullivan sullivan is offline
Vehicle: 2006 Dodge Ram Sport 5.7
Rep:202
sullivan has a spectacular aura aboutsullivan has a spectacular aura aboutsullivan has a spectacular aura about
Having the halos on the blinker is kinda dumb in my opinion.
06' Sport - 3.92 Gears - Superchips - Bilstein Shocks - HellWig Anti-Sway Bar - Cooper Zeon LTZ - Viper Alarm & Remote Start - Halo Projector Lights - 5k HID Lows & Fogs - Custom Emblems - Magnaflow - CAI
