Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > Dodge Ram Special Edition Models > Dodge Power Wagon
Old 06-18-2013, 09:00 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I have no extra accessories, however, want to do this mod so bad!!!! lol
Sean
Old 08-06-2013, 09:34 PM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:256
So bumping this to the top because I just got all the parts for this!!!!!!!!!!!!!!!!
Well, all the factory parts that is. I am going to emulate the OPs but will keep mine as a completely separate circuit and harness. Now just to get a weekend off and be able to put this together!
Spyntec Hubs, 35" Cooper STT, Synergy Steering Brace, out of money........................
Old 08-06-2013, 11:22 PM
Txhillbilly's Avatar
Txhillbilly Txhillbilly is offline
Vehicle: 2012 Dodge PowerWagon
Rep:41
Txhillbilly is on a distinguished road
I'm waiting to see it done on your truck also.
Let me know if you need help with the wiring diagrams.
Old 08-06-2013, 11:49 PM
Rep:256
I will definitely take any pointers or diagrams you already have.
Old 08-12-2013, 01:05 PM
cbiels's Avatar
cbiels cbiels is offline
cbiels is on a distinguished road
Default harness specs
I was about to do this mod myself and was looking to see if anyone already had. Would you mind sharing the harness setup with me? You'll probably save me a headache. Thank you
Old 08-13-2013, 12:29 PM
Rep:256
Work is pretty busy with me right now. Once I have time to sit down and wire everything up I will detail it all. I know the OP has some diagrams and photos he can share as well.
Old 08-14-2013, 02:24 AM
Rep:41
OK guys,Here's a couple wiring diagrams for the Aux switch set up.
This first one is for the switch panel wiring.
If you look at the back of the Aux switch panel where the plug goes in,you will see on the right side there is a blank gap between the top pin and the second pin. Leave the hole in the wiring plug empty for this one.
The top left (1) and top right (7) are your 12v hot input wires. I just tied into the positive side of the drivers side 12v accessory plug on the dash panel for this connection.It's only hot when the ignition is on,so your switches only work when the ignition is on.
(2) is the ground wire,there is a grounding point behind the dash panel on the glove box side of the dash to wire the ground to.
Wires 3-6 are your output wires that go to the relays,and will be hooked up to the 85 side of the relay.
There's plenty of room behind the dash for all of the relays,and I just taped all of them together,and wired them up together.
Here's how to wire up the relays-
The Aux switch outputs go to the 85 side of the relay.
The Positive wire for your lights,etc. go on the 87 side of the relay.
The hot wire from the battery will go to the 86 side of the relay,and then make a jumper to the 30 side of the relay,and continue doing this for all of the relays and you will only have one wire coming from the battery.
I made a complete wiring harness with 5 different colored wires first,and noted what each color wire was for (switch 1-2-3-4,and battery).
There's a plastic block off plate on the firewall where the clutch pedal would go if it was a manual tranny.If you take that plate off,you can drill a hole in it to run your wiring harness through,and just seal it with some silicon when you get it all installed.
Wire the positive side of your lights to the switch harness,and I just ran the ground from the lights to the negative post of the battery.
Good luck,it's pretty simple to do this. If I can do it,anyone can!
Old 08-19-2013, 07:11 PM
Rep:256
Alrighty, so my switch panel is in. I got lucky I guess, on the back of the RAM insert was a blank socket with a three wire harness running to it (heated seat harness maybe?). It had two hot 12v and a ground, the plug fit excactly the switch pannel but the leads were in the wrong pin holes. I used the two hots for my two 12v sources and used the harness ground on the passenger side. I then built a 10' harness and ran out the blockoff for the clutch pedal and ran along the inside of the fender with the factory harness to the TIPM module. Right now the harness is terminated there. I am deciding on wether or not to build my own 4 relay block or just buy an sPod and use that.
Old 11-05-2013, 11:02 PM
Firsttruck Firsttruck is offline
Vehicle: 2005 Dodge Ram
Firsttruck is on a distinguished road
Thanks man you have no idea how much this helps with my install
Old 05-19-2014, 01:30 PM
adeluca73's Avatar
adeluca73 adeluca73 is offline
Vehicle: 2014 2500 PW SLT
Color: Flame Red two tone
adeluca73 is on a distinguished road
Default 2014 PW aux switch panel quesiton
First, I read through this entire thread, and I have to say, it never ceases to amaze me how creative and enterprising people are with stuff like this.
Second, I ordered a 2014 PW SLT, and during the ordering, had to make a choice between the 9-spkr premium audio system and the aux panel switches. I have no idea why Ram doesn't allow you to choose both of those options, but you can't. It's one or the other (both were about $325 add-ons), and all I can think of is it's either a power managemnet issue, or a space behind the radio head issue. I ordered the 8.4AN radio head and went with the 9-speaker audio option since the audio would be used far more than the upfitter switches, and I figured adding a homemade mod for the aux switches would be easier and more feasible than trying to add the speaker upgrades later. I do want to install aux switches, does anyone know if it is possible to install them, and if so, what is required?
Thanks.
2014 Ram 2500 Power Wagon SLT, everything but sunroof & ram boxes, mods as $$ is available...
