Old 08-13-2012, 02:03 PM
Central Coast Mopar's Avatar
Central Coast Mopar Central Coast Mopar is offline
Vehicle: 2001 Dodge Ram Sport
Central Coast Mopar is on a distinguished road
Default Off Road Package.... HELP!
I have a 2001 1500 Sport with the factory off road pakage, I'm searching for an aftermarket kit or any do-it-yourself options to get some lift out of it. Preferably greater than just a 3" leveing kit. Also if I go with a leveling kit do I have to move the track bar or anything else too?
Old 09-02-2012, 11:03 PM
Skull1313's Avatar
Skull1313 Skull1313 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: SRT2
Skull1313 is on a distinguished road
Send a message via Yahoo to Skull1313
You can choose any kit. They will all work for your truck. The only exception is that you will not gain the full 5 inches of lift because you already have 2 inches from the factory. 2" longer springs in the front and a 2" block in the rear. The leveling kits are nice and are done in a few hours and pretty cheap. If you want a cheap way go with the leveling kit 2". Then put in a 3" body lift. You'll have 5" for like under 300 bucks. Easily clear 35's. My stock factory off road package clears 33's with no issue. Some lift kits (most of them actually) Come with a track bar relocation bracket. If you do a leveling kit you do not have to move the track bar. If you start changing the geometry of the front axle then its required. I hope this helps a little. this was explained to me so I'm just passing it along. Good luck.
Old 12-26-2012, 11:19 AM
mopardoug's Avatar
mopardoug mopardoug is offline
Vehicle: 2001 Dodge 4X4 Offroad sport
Trim Level: Laramie Sport
mopardoug is on a distinguished road
Wondering if you did the leveling and how you like it?
2001 Offroad sport, 1979 Lil Red Express, 1977 Ramcharger SE 440, 1972 Duster
lift, lift kits, off road, suspension
