Old 08-12-2012, 03:54 PM
cape99ram's Avatar
cape99ram cape99ram is offline
Vehicle: 1999 dodge ram 1500 4x4
Trim Level: slt laramie
Color: silver
cape99ram is on a distinguished road
Nice...just wonderin'...how'd you get to it?
dropped the tank with a tranny jack and the line connects to bottom of the filter thats mounted on the pump. it actually happened tuesday too. kinda realized that there was a reason the pump was only $113.... if you ever buy one, snip the plastic piece out of the line on the bottom of the filter, and put it back on with a good strong clamp. the plastic was swelling up and would cause the line to fall out. and i ordered a felpro intake plenum gasket for $12 at autozone yesterday.. how long does it take to replace?
Old 08-12-2012, 04:08 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
You're going to have to pull the intake manifold so you'll need those too.
I'd power-wash the engine and soak the intake bolts with a healthy dose of penetrating oil over night.
I'm not sure of your experience but if you cover your bases and there's not any unforeseen circumstances 2-3 hours tops.
Old 08-12-2012, 11:14 PM
cape99ram's Avatar
Color: silver
ohhh yea thats true i should get all the gaskets thanks haha. and the engine bays is pretty clean so i dont really think ill have any issues with that. all you do is pull the intake manifold and the plenum is on the underside of it?
Old 08-12-2012, 11:21 PM
Vehicle: 95
Rep:1776
Yep. You'll have to unhook the throttle body (cables wires etc.) Pick up an $8 set of fuel line tools so you can pop that off, The dist. stays.
Old 08-19-2012, 12:12 PM
cape99ram's Avatar
Color: silver
it looks like the accessory bracket is gunna have to come off too? i had to take it off to get to the coolant bypass hose... and when i put the new gaskets in, should i use any rtv? get new bolts? any suggestions?
Old 08-19-2012, 01:20 PM
JeffreyCH's Avatar
JeffreyCH JeffreyCH is offline
Vehicle: 1996 Dodge Ram 1500 4x4
Trim Level: SLT sport
Color: red
JeffreyCH is on a distinguished road
I've never used RTV on the couple I've done. You will need a torque wrench, the specs, and sequence to install/torque the bolts. I have the service manual on pdf. I think I downloaded it from a link on this site.
New bolts aren't a bad idea, I re-used the main bearing bolts on a 350 build years ago, 10 minutes after it started I heard the death rattle of a thrown rod. Another thing I do is run a tap down the threads with some WD40 to clean out the threads, then use some blue lock tite (I do this on pretty much anything I do) be sure to blow the WD out with degreaser (I use brake clean) Hope that helps
Old 08-22-2012, 11:50 PM
cape99ram's Avatar
Color: silver
yea im buying a torque wrench this week and getting all my torque specs off mitchell1... ive read a few things about snapped bolts in the plenum?
5.2, fuel pump, stalled
