Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 07-20-2012, 06:02 AM
davidtalley
Default cummins going crazy
hey guys i need some expert advice!! my truck is trying to pull away when i stop at a light, it will not stall down. it will actually pull so hard that it starts puffing smoke. not to the extreme were its gonna break loose and start spinning but def. enough were if you took your foot off the brake you would get a grill full of tail lights.. ok that being said i have tried a stall test which it past. also replaced the govenor pressure solenoid and transducer, new clock spring, run the brd scanner on it and its throwing no codes. i did buy the noise filter from bd for the apps but have not installed it yet. the fly by wire pedal has been re married to the truck and supposedly was not an issue.. im lost!! other than buying a new TC and just trying it out which is a lot of money just to " see if it works" i dont know what to do next!!! any help would be greatly appreciated
Old 07-23-2012, 02:08 AM
davidtalley
Anybody ever had this happen to them?
Old 08-02-2012, 03:57 AM
davidtalley
any help would be appreciated guys!!
cummins, not stalling
