Old 07-11-2012, 02:04 PM
Canviper's Avatar
Canviper Canviper is offline
Vehicle: 2006 Dodge Ram SRT 10
Trim Level: SRT-10 Nightrunner
Rep:26
Canviper is on a distinguished road
Very nice truck. Quick question How did you black out the front and back Ram heads. Did you pull them off and paint them. Or did you mask of around the badges and spray paint them. And what kind of paint did you use.
NIGHTRUNNER #167/#400 MODS: K&N CAI, BBK TB, BORLA EXHAUST catless, AMERICAN RACING HEADERS, SCT TUNED By Chris Jensen. My album is finally up come check out some pics.
Old 07-11-2012, 02:07 PM
+1
They don't look like plastidip.....what did you use?
Old 07-11-2012, 10:00 PM
BillSRT8 BillSRT8 is offline
Vehicle: 2012 Dodge Ram
Color: Mineral Gray Metallic
BillSRT8 is on a distinguished road
Thats what I was thinking too .... if I go 35's the wheel well will be 'stuffed'...
Ive hear nothing but good things bout those terra grapplers and that is on my decision list.
Terra Grapplers or Baja ATZ
Where did you grab the tires if you don't mind me asking?
Even with a +18 offset, there is no rub?
I though -12 was the ideal or 0 at most....but great news is that you are not experience rubbing....
I guess that has to do with the rubber also be 12" wide vs 12.5" that a 33x12.5 would give you.
They are 12.4 inches wide. +18mm is most likely the absolute closest you can go without the rubber hiting the upper control arm. There is an 1/8th of an inch between my upper control arm and the tire itself, but it does not rub at all anywhere. A local shop around here some buddies of mine run ordered the tire/rim package for me, not sure of the source.
Front and back ram heads, as well as the grill, were all taken off and sprayed in a paint booth with legitimate car paint.
Old 07-11-2012, 11:56 PM
My calculations tell me it's 12" wide.....
If +18 works with no rubbing....(those are the tires I want) then I should be ok
Old 07-12-2012, 11:26 AM
I got the 12.4 off of nittos site. yeah you should be fine, keep in mind my trucks leveled, idk if yours is or not
Old 07-12-2012, 11:31 AM
Mine will be leveled via 5100's.
Still debating if I should get the rear 5100's and either set them on .5' or 1" and crank the fronts all the way up to 2.8"
It will be almost level but give me a slight rake...
Or should I just to the fronts and crank them to 2.1 (think thats the second setting)
Thoughts?
Old 07-12-2012, 11:54 AM
Thoughts?
I have a 2 inch block up front and the truck still sits slightly raked, which is what I prefer, I do not like the squatting look at all. You should be fine with just the fronts
Old 07-12-2012, 12:54 PM
This will more than likely be the route for me. If I feel the need to crank up higher, Ill get the rear and crank the fronts to 2.8"
Old 07-14-2012, 04:27 PM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:62
Looks great. Wish I coukd have gotten a sport instead of the big horn I love the color match over all the chrome.
Old 07-14-2012, 05:31 PM
RAM-RT's Avatar
RAM-RT RAM-RT is offline
Vehicle: 2011 Dodge Ram R/T
Trim Level: R/T
Color: Metallic Grey
Rep:29
RAM-RT is on a distinguished road
Very nice truck
