Old 06-29-2012, 11:47 AM
swordmetal swordmetal is offline
Vehicle: 1999 Dodge Ram 1500
swordmetal is on a distinguished road
Default Leveling Kit with a Suspension Lift?
Hello everyone, I just bought my first Ram and I've got my first of many questions I'm sure. I've got a '99 1500 Laramie 4x4. A previous owner installed overload springs in the rear and claims to have installed a 2" lift. There is no body lift so I've got to think it's suspension, as the truck definitely sits higher then stock height. However, the truck still has the factory rake that I would like to get rid of. I've heard bad things about running a leveling kit with lifted suspension. Thoughts? Maybe stiffer/taller springs in the front? This is my first taste of the full size truck and suspension lift world so please forgive my ignorance. Thanks for all the help!
Old 07-08-2012, 10:30 AM
Howells's Avatar
Howells Howells is offline
Vehicle: 1999 dodge ram sport 5.9l
Trim Level: sport 4x4
Rep:19
Howells is on a distinguished road
Lots of people run leveling kits on there suspension lifts. It's up to you. I have a 5" lift with a 1" leveling spacer. Just the bigger the spacer the more your axle will shift if you don't get longer control arm and trac bar. I don't know if there is a 2" lift out there that isn't a spacer. Unless it's got the offload package springs or 2500 coils a pick of the front coils would help. Good luck.
Old 07-08-2012, 10:33 AM
Howells's Avatar
Rep:19
Oh and if your running the factory shocks and there is already a 2" lift you will need longer shocks. At 2.5" lift the factory shocks are pretty much maxed.
Old 07-19-2012, 12:55 PM
Big Green V10's Avatar
Big Green V10 Big Green V10 is offline
Vehicle: 2000 Dodge Ram
Color: Green
Rep:31
Big Green V10 is on a distinguished road
You need to send pics as the previous owner might not have know what he was talking about it does happen. Most overload springs don't raise the truck in fact don't do anything untill truck is fully loaded. Take a few quick pics and post em and then we can give good advice. My guess is as most people think there ram sits higher than stock which is because they do sit higher than most other trucks is that is is stock. You want to be sure what you have before you buy any parts.
2000 Dodge Ram 2500 4x4 Ext Cab V10, 12" Suspension, 3" Body, 46x19.5x20 Baja Claws
leveling, lift, shocks springs, suspension
