Old 06-14-2012, 10:27 PM
gotbrains230's Avatar
Vehicle: '12 RAM 1500
Rep:420
I thought the error cancelers were the relay harness, I really didnt think there was a difference. But now I know
MATT
Old 06-15-2012, 01:14 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Error cancelers are a capacitor that goes inline with the ballasts/bulb and creates more load in the system tricking the truck into thinking they are standard bulbs
relay harnesses use a relay(s) to use the stock wiring harness to trigger a relay that draws and directs power from the battery to the ballast giving you a most constant/direct flow of power to help reduce the chances of flickering
2011 Big Horn 4x4 -SnowWhite-
Old 06-15-2012, 01:21 PM
Rep:420
Thanks for clearing that up
If I'd known that when I did mine, I damn sure wouldn't have used the harness. What a headache that was lol
MATT
Old 06-15-2012, 02:04 PM
SS4Luck's Avatar
Rep:310
No problem. Ya harnesses are a nightmare and a lot of people hae been told things by shops that arent true and thinkg thats how it HAS to be. The only time I start with a harness is when its a bi-xenon and thats simply because usually you have to have a harness with those because of the extra power drawn by a single bulb dual light combo
headlights, hid kits, hid lights
