Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 > MDS
MDS Multi Displacement System Discussion
Old 05-29-2012, 05:23 PM
BMosh's Avatar
BMosh BMosh is offline
Vehicle: 2008 Dodge Ram 1500 4x4
Trim Level: Big Horn Quad Cab
Rep:15
BMosh is on a distinguished road
Default RPM with and without MDS
When MDS is engaged or disengaged, what is the RPM when cruising at 65mph on the freeway?
I have an 08 4x4. I have mine tuned with MDS off. Truck is running about 1600 RPM on the freeway at 65mph. I've noticed what might be the MDS drone, but I recently swapped mufflers and it might just be that I am still adjusting to them.
My buddy has an 06 with no MDS and he runs at 2000 RPM at 65 on the freeway.
Could it be that even though I set my Trinity's parameters to shut MDS off, that it is in fact still engaging?
Old 05-29-2012, 06:33 PM
Rep:2625
If your friends Ram is a 2006 1500 model with a HEMI, he has MDS
if it is a 2500 or 3500 it will not have it
I drive my 2009 HEMI powered Ram across the flats with 1000 pounds of extra weight in it
you can see for yourself the speed, RPMs, outside temperature, & MPG
The MDS is engaged in this photo, it reads FUEL SAVER on mine when it is engaged
Cruise Control is also on
Old 05-29-2012, 11:01 PM
I push the skinny pedal
Rep:3277
I'd double check to see if you've actually deactivated the MDS. After that I'd check if you're just running in O/D and getting that low RPM as my '07 can sound pretty weird when cruising at highway speeds. I have my MDS programmed out with a custom tune and even with my cutout it will sound limp at low RPM when cruising.
Kurtis
Old 05-29-2012, 11:09 PM
BMosh's Avatar
Rep:15
it is definitely set to off. Im thinking its just the different muffler. Thanks for the replies.
Old 08-20-2012, 04:39 AM
KarateManAZ's Avatar
KarateManAZ KarateManAZ is offline
Vehicle: 2009 Dodge Ram
Trim Level: MagnaHEMI
Color: Deep Water Pearl Blue
Rep:120
KarateManAZ will become famous soon enoughKarateManAZ will become famous soon enough
I'm sure he has different gears or different size tires....
2009 Ram 1500 Crew Cab - Deep Water Pearl Blue
2/4 Drop, 0212353 Retro Shop Projector Retrofit w/ custom paint, Jet 180 T-Stat, AR LT Headers, 545rfe w/ deep pan,
Inertia Cam, Edge Triple Disk, Magnaflow 18"
Oh Yeah its a MagnaHEMI 12.2@109
