Old 04-25-2012, 02:13 PM
rsnyderjr2 rsnyderjr2 is offline
Vehicle: 1999 Dodge Ram 1500
Trim Level: SLT Laramie
rsnyderjr2 is on a distinguished road
Default a couple of newbie questions
Hi Guys -
I'm the proud new owner of a '99 1500 Laramie w/Automatic tranny - it didn't come with an Owner's Manual (although I have ordered one) - and I was hoping that someone could tell me the proper way to shift around between 2wd and 4wd...
I'm assuming that it should be in either Park or Neutral - and ok to do it with engine running, or not? Etc.
Also, I seem to have the basic stock radio w/cassette deck - I don't suppose there's a chance in hell that it has RCA low level output jacks I could run an aftermarket amp to?
Thanks Guys!!
Ritch
Old 04-25-2012, 02:21 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Nut or park is correct. Some say it can be shifted on the fly below 10 mph. I don't sugest that my 4x4 gets pissie when you do that. No there are no rca jacks for after market amps. Get a better head unit for that also use a wire instal kit much easer.
Old 04-26-2012, 09:07 PM
marshall0792's Avatar
marshall0792 marshall0792 is offline
Vehicle: 98 Dodge Ram Reg Cab Long Bed
Trim Level: SLT 4x4
Color: White/Gray
marshall0792 is on a distinguished road
I know that you can shift from 2 hi to 4 hi while still moving but it takes a second for it to finally engage, but to shift in and out of 4 low you have to come to a full stop, be in either park or neutral and you have to move the lever in one quick movement or it will grind a little bit.
rca, stereo
