Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 > Exhaust
Exhaust 5.9L Exhaust Discussion
Old 04-15-2012, 05:17 PM
RAMitover2001's Avatar
RAMitover2001 RAMitover2001 is offline
Vehicle: 2001 Dodge Ram
RAMitover2001 is on a distinguished road
Default Single Straight (w/ cat), Dual Straight(w/ cat), or Dual glasspacks
Ok so at the moment I am running Stock everything except muffler. It is an 18in glasspack, and it is not loud enough haha. I was wondering what i should do out of these three options; run single straight(w/ stock cats), dual straights(w/ stock cats), or run dual 18in glasspacks. I want it to be LOUD Any feedback?
Old 07-31-2012, 09:32 PM
ramman97's Avatar
ramman97 ramman97 is offline
Vehicle: 97 ram 1500
Color: red
ramman97 is on a distinguished road
im in the same boat bro i got stock set up i was going to run just cat then straight out to the tail pipe didnt kno how it will sound tho..if i come across some anwsers ill let you kno
Old 11-05-2012, 07:56 AM
POPER's Avatar
POPER POPER is offline
Trim Level: SLT Laramie
POPER is on a distinguished road
So did you guys end up going to straight pipes? I think I'm going to be pulling out my muffler this week - she's way too quiet...
2001 5.9L Laramie SLT - En route to "custom"
Old 11-05-2012, 09:06 AM
REDRAM24 REDRAM24 is offline
Vehicle: 2009 Dodge Ram
Trim Level: SLT Crew Cab
Color: RED
Rep:49
REDRAM24 is on a distinguished road
i ran true duals with flowmasters and its not to loud but when you get down on it its pretty loud but it does not have that redneck rap sound. my wife and kids said it sounds like a racecar and some other people said it has the mustang sound
Old 11-05-2012, 09:47 AM
BrandonMski's Avatar
BrandonMski BrandonMski is offline
Vehicle: 2006 Dodge Ram 3500
Rep:24
BrandonMski is on a distinguished road
Yes loud exhaust is bad ass but also consider how it sounds. On my first Ram I ran straight pipes from the Cat back and it was loud as hell but the sound wasn't mean. (honestly kind of annoying) On my current Ram I have a 18" glass pack. It's not as loud but it sounds like it will eat you.
2000 Dodge Ram 1500 Sport 4x4 - 5" lift, 36" tires, CIA, exhaust, CB radio, bed liner, undercoated, and more
2006 Dodge Ram 3500 Laramie 4x4 - trans temp, EGT, boost gauges, 5" exhaust, CIA, Fass 95GPH
Old 02-03-2013, 05:30 PM
crazedgrizzly's Avatar
crazedgrizzly crazedgrizzly is offline
Vehicle: 1996 dodge ram 1500
Color: red/black
crazedgrizzly is on a distinguished road
thinking the same but does the cat create enough back pressure so you dont end up burning up your valves
Old 02-07-2013, 12:42 AM
ElSombreroNegro's Avatar
ElSombreroNegro ElSombreroNegro is offline
Vehicle: 1996 Ram 1500
Rep:17
ElSombreroNegro is on a distinguished road
take it from someone who runs a 350 with open long tubes at the track: unless you are running lean, lack of back pressure will never ever burn your valves.
Also, back pressure is always, always bad and never ever ever any good, ever. (unless you run a turbo with it). What you REALLY want is high exhaust velocity, low back pressure, and tuned primary lengths to optimize exhaust scavenging through carefully timed pulses creating a vacuum signal on the valve behind the outgoing exhaust pusle, which is a fancy way of saying the POLAR OPPOSITE of back pressure. THIS is what helps your low end torque by increasing your volumetric efficiency.
Old 02-16-2013, 04:25 PM
damnkidd012 damnkidd012 is offline
Vehicle: 97 ram 2500
Trim Level: base
Color: green
damnkidd012 is on a distinguished road
I have stock manifolds with magnaflow cat 3 inch piping and a flowmaster 40 and its loud as hell dumped on the right side in front of the axle
Old 05-30-2013, 10:40 PM
Yee Yee 360 Yee Yee 360 is offline
Vehicle: 1999 Dodge Ram 1500
Yee Yee 360 is on a distinguished road
Im in the same situation. I really love the sound of my thrush glass pack but it just isn't loud enough for me.... but im afraid of any problems a straight pipe would cause, if there even is any. Ive got stock manifolds and cat and the only thing I changed was the old huge stock muffler to a thrush. But as far as sound, im not too sure what would be better, single straight or dual. Any suggestions? thanks
2001 dodge ram, dual exhaust, glasspack, straights
