Old 06-06-2013, 12:57 PM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
hmm, not sure what happened when you tried the link. I just downloaded the file from it with no issues. I had 2 different updates listed on this forum. (1) was for the iPod error occurred issue and the 2nd was for BT streaming audio sound quality. But they had to be done in that order also. If you haven't applied the 1st update and want to do both, then I have a link to do them both at once so there isn't any mistakes. The instructions are the same as previously listed in #41.
(make sure to rename the file to be uconnect.upd)
http://www.mediafire.com/download/3u...e_uconnect.upd
Originally Posted by RAMeister View Post
Just stumbled across this thread. It appears the mediafire.com links mentioned in post #41 are no longer...or perhaps its only down temporarily??
Any other sources?
TIA
Old 08-11-2013, 11:20 PM
krazyram krazyram is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: Larime Sport
krazyram is on a distinguished road
Default Ugh!
I tried the update on my 2011 Dodge Ram 1500 with the RHB nav radio with uconnect and when it gets to the end of the update or what I guess is the end of the update it says used digital signature not valid or something like that. Whats that even mean?
Old 08-13-2013, 09:28 AM
Rep:73
I have seen this issue before and it was the thumb drive. Please try a different thumb drive. I have also had a couple people that tried a different USB port on their computer to download the file to.
****edited question****
I just noticed that this is the 2012 update thread, you mentioned that your truck is a 2011. Do you know what the build date is? This update may not be the correct one for you depending on that date. Thanks
