Old 10-21-2013, 11:25 AM
russ244 russ244 is offline
Vehicle: 2011 dodge ram 1500
russ244 is on a distinguished road
Default back seat dome light
would like to no how to change light blub in the dome light back seat any help would be great
Old 10-22-2013, 05:57 PM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
It's not difficult. The cover just pops off. You may need a thin bladed screw driver or trim tool. Just start on one end, it'll pop loose, and you can pull it the rest of the way off.
In my '10 it will sort of hang by some sort of plastic piece once it's popped loose.
You can then reach in and pull the old bulb out, and replace it with the new.
The cover will go back on just as easy as it came off. Just start on one side and then do the other.
good luck
Exco
Bill
