Old 01-12-2013, 06:51 PM
AbnMP13 AbnMP13 is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Longhorn Laramie
AbnMP13 is on a distinguished road
Different model years need resistors.
SFC, US Army
Retired
Old 01-12-2013, 08:38 PM
InDeepWaterBlue's Avatar
Rep:611
Originally Posted by 06PowerWagon View Post
I have LED lights for the following ... Side marker Lights ... the dome light ... map light... inside the heater control nobs... instrument cluster... over head console... and even my cargo light... and I have no Resistors on them and the only resistors i have are on my LED Turn TIPM problem...
3rd gen wiring is different than us 4th gens, we need resistors for more LED's than 3rd Gens
Old 10-21-2013, 11:22 PM
brondondolon's Avatar
brondondolon brondondolon is offline
Vehicle: 2009 Dodge Ram 5.7L hemi
Trim Level: 1500
Rep:177
brondondolon has a spectacular aura aboutbrondondolon has a spectacular aura about
i had such a nightmare with my leds in the tail lights i gave up and am running stock. what sucks is i bought some cree led with 20 smd leds on the side that are brighter then hell only because i have smoked tail lights. i used a common load resistor that you hook up to the wires but i was faced with every problem. one way the lights would work but no break light the other way only break lights would work and no running lights. then i flipped the bulb and every thing worked and i got a bulb out error and they stopped working after that so then i put the resistor on another cable since there are 3 and then they wouldnt work. would soldering in this little resistor fix my problem?
S&B CAI, Y-pipe muffler delete, Diablo intune, Hemifever, custom tune, 180 thermostat, BT oil catch can, smoked, tail light and 3rd breaklight, 5000k retrosolutions 55w HID headlights and fog lights, LED in all exterior lamps, red calipers. Future mods: 87mm TB, 3000 stall torque converter
Old 10-23-2013, 12:31 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Soldering will not help much with your problem.
Did you install the resistors like this picture with the correct resistors? You need a resistor for each LED bulb.
I would use the 6 OHm 50 Watt resistors.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 10-23-2013, 05:49 PM
Trim Level: 1500
Rep:177
yup i did it exactly like that. i have them sitting in my garage collecting dust as of right now i think the bulbs only are meant for on/off function or something idk what the deal was.
Old 12-08-2013, 05:00 PM
scaredstr8 scaredstr8 is offline
Vehicle: 2014 Ram 1500 Big Horn Crew
Color: true blue pearl
scaredstr8 is on a distinguished road
Default license and reverse lights
i have a 2014 slt big horn 1500. I just installed the license plate lights, and reverse lights and cargo lights. The problem i have is with the license plate lights and the reverse. It comes up on my display when i start the truck that the license plate and reverse lights are out. Which resistor should i install to correct this problem. Thank you for your help.
Anthony
Old 12-09-2013, 10:54 AM
gcscott's Avatar
Rep:1043
Anthony
You need to add a resistor to make up for the lower current that the LED's draw.
Check out the Load Equalizers / Resistors section here: http://www.autolumination.com/equalizers.htm
Page down to Load Equalizers / Resistors.
I think you will need the second one (Rated 25 watt LED Load Equalizer) It goes by amount of watts so you may need a higher one depending on what bulb you replaced.
Greg
Old 01-19-2014, 03:04 PM
NY Ram 86's Avatar
NY Ram 86 NY Ram 86 is offline
Vehicle: 2013 Dodge Ram 1500
Trim Level: Tradesman Express
Rep:19
NY Ram 86 is on a distinguished road
Originally Posted by mikeski View Post
Sorry it took so long. I was made an offer I could not refuse ;-)>
I soldered on the 100 ohm 1watt resistor on both the lights. Worked like a champ.
I am trying to do the same thing with soldering the resistors; does it matter how and where they are soldered on? And is that black tape you used to cover something?
Old 01-21-2014, 07:39 AM
ghorn ghorn is offline
Vehicle: 2012 Ram 4X4 Crew CAb
Trim Level: LoneStar Rambox
Rep:74
ghorn will become famous soon enough
Hmmmn... I wonder...
I added two LED cluster type lights under my tonneau cover and tied them into my cargo light wiring. They work just fine...except occasionally they don't. I first noticed that occasionally the "illuminated entry" feature did not work reliably. In other words, the cargo light would not illuminate when using the key fob.
Here's how they fail: If the truck is running with headlights on...and I turn on the cargo light using the switch by the headlight switch...the cargo light flickers one time and dies. It will be a week before the cargo light will work again. Then... If the truck is NOT running the cargo light works fine. But if I start the truck, turn the headlights on, and then request the cargo light... it flashes just momentarily...goes out for another week.
Anyone believe this has anything to do with the LED lights in parallel to the cargo light?
Old 04-07-2014, 01:24 AM
da92gs87 da92gs87 is offline
Vehicle: 2011 Ram 1500
Color: Bright Silver Metalic
da92gs87 is on a distinguished road
Only issue i have the the blinkers starting out normal, then going to the fast mode. What and where is the electronic blinker thing you guys are talking about?
K&N, 180 t-stat, BD Hemi Plus, Moes 85mm, BT CC, KMC Strikes, 35's, 6" RCX, Ranch Hand, HID's
