United Radio
Old 07-16-2012, 01:42 AM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:62
If you buy a electronic flasher to replace the mechanical one the truck it will solve the fast flash issues I use them on turn signals as opposed to resistors. I find it a cheap easy one part install fix.
Old 07-22-2012, 10:38 PM
AbnMP13 AbnMP13 is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Longhorn Laramie
AbnMP13 is on a distinguished road
Does the cruise work with the electronic flasher?
SFC, US Army
Retired
Old 07-23-2012, 09:55 AM
InDeepWaterBlue's Avatar
Rep:611
As in cruise control??? Cruise control isn't affected by the flashers, but I'm not sure that's what you mean here
Old 07-23-2012, 10:38 PM
Pyroboy5000's Avatar
Pyroboy5000 Pyroboy5000 is offline
Trim Level: TRX
Rep:37
Pyroboy5000 is on a distinguished road
he means running lights i think.
I'm back from the dead!
R.I.P Old Blue 2013
Old 07-24-2012, 03:13 AM
Rep:611
Oooh as in Daytime Running Lights (DRL's) that would make a lot more sense lol. your side marker will still light up and everything will be ok until its used as a blinker, then you'll get the "Lamp Out" signal. It will still blink as well, you'll just have the warning light on your dash
Old 09-04-2012, 05:56 PM
Phillylunatics20 Phillylunatics20 is offline
Vehicle: 2005 Dodge Ram
Phillylunatics20 is on a distinguished road
where is the picture of what it should look like?
Old 09-07-2012, 01:58 AM
Ramboi92's Avatar
Ramboi92 Ramboi92 is offline
Vehicle: 1995 Dodge Ram 1500
Trim Level: Laramie SLT
Color: Pearl Emerald Green
Rep:13
Ramboi92 is on a distinguished road
I installed projector/LED headlights and LED tail lights and 3rd brake light. I have a 2nd gen, and my blinkers flash VERY slowly. I've heard that an LED flasher relay from superbrightleds.com will fix the problem. I ordered the relay and will update the result when I get it put in.
Nitto Trail Grapplers wrapped around 18" Mamba M3's. They'll take me anywhere. In 2wd.
Old 12-09-2012, 12:21 PM
Originally Posted by mikeski View Post
Sorry it took so long. I was made an offer I could not refuse ;-)>
I soldered on the 100 ohm 1watt resistor on both the lights. Worked like a champ.
What bulbs did you solder the resistors onto?
SFC, US Army
Retired
Old 01-05-2013, 05:49 PM
mc7719 mc7719 is offline
Vehicle: 2011 RAM 3500
Trim Level: Laramie Longhorn
Color: Deep Cherry Red
mc7719 is on a distinguished road
hooked up these for my cargo lights.. thanks for the resistor idea!
Abbotsford, BC, Canada
Old 01-12-2013, 07:37 PM
06PowerWagon's Avatar
06PowerWagon 06PowerWagon is offline
Vehicle: 2006 Dodge Ram 2500
Trim Level: Power Wagon
Rep:26
06PowerWagon is on a distinguished road
[QUOTE=SS4Luck;740433]Okay guys, I think i finally made a breakthrough...
For the guys having filckering/glowing/stupid LED issues... It seems that regardless of the bulb color/style/location a 100Ohm 1W resister soldered to the LED fixes any issue so far i have ran across. the only possible issue I can see affecting this would be the weird when the trucks not running they work but when the tuck is running they do.
I know i said i would never go there, but from now on it is going to be my recomendation where if you have one of the trucks that has LED issues, those are the resistors to try.
I do not know if this will work with the blinkers and the "bulb out" notification. I ran out of resistors tonight when I did my neighbors truck, Imma pick up a few more Monday afternoon and try it, but until the the answer to 921/194 style problems appears to be this little baby resistor to actually create the right load in the circuit.[QUOTE=SS4Luck;740433]
I have LED lights for the following ... Side marker Lights ... the dome light ... map light... inside the heater control nobs... instrument cluster... over head console... and even my cargo light... and I have no Resistors on them and the only resistors i have are on my LED Turn TIPM problem...
Smile even if its a little creepy
