Old 02-27-2012, 10:57 PM
djdavekl djdavekl is offline
Vehicle: 2006 Dodge Ram 1500
Trim Level: SLT Sport
Color: Grey
djdavekl is on a distinguished road
Unhappy various issues
OK, here goes.... First off my bad if it's not in the right spot.
1) my signal light is not functioning properly, when in the left position, it flashes right, sometimes both, sometimes nothing... same if in right position.
2) I have the 20" stock rims, on an 06 SLT Sport. I put on a set of Duratrac 275-65-20's on, will I have speedo and rubbing issues.
3) my back seat is not raising properly, the small section works fine, but the bigger side won't go up, like it needs a latch released or something... but I cant find a latch.
4) last one for now I have the infinity stereo system... with uconnect. is there an aux hidden somewhere???? and if I put an aftermarket stereo, will I lose the uconnect.
Thanks again in advance for the help!!!!
Old 02-28-2012, 07:12 PM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
On #1-- Does the emergency flasher work all lights correctly? I believe that the multifunction switch (turn signal lever) goes into the E - flasher, could be bad.
On #4, if it is a factory installed Uconnect system, look in the glovebox or center console (if equipped) for a red connecting plug like the one pictured. If so then it is for an iPod to plug into and the parts dept will have the short cord for iPod use. If you do replace the factory stereo, yes you will lose Uconnect. The other side of the coin is, depending on the radio you're looking at, a lot of them have bluetooth and aux inputs built in.
Old 02-28-2012, 11:53 PM
bucks bucks is offline
Vehicle: 2004 Dodge Ram 1500
Rep:17
bucks is on a distinguished road
#2- 275/65's are about an inch bigger than the stock plus size (34.1 compared to 33). The width on them is the same. Your speedo will be out some. As for rubbing issues I doubt you'd see any unless you had your suspension on full compression. Turn the front wheels all the way one direction and all the way the other to see if it rubs on anything.
2004 Dodge Ram 1500 Hemi Sport, AWD, Muffler delete
Old 03-01-2012, 10:58 PM
dork's Avatar
dork dork is offline
Vehicle: 2006 Dodge Ram 1500 Hemi
Color: Brilliant Crystal Pearl Black
dork is on a distinguished road
My 06 Ram does the signal thing too. But only when it's below zero degree weather. Kinda weird. I did get a recall about turn signal malfunction in the mail though.
55w 5k HID, 35w 5k fogs, LED everything, Black 3.5mm grille with rebadge, Debadged/demolded, Painted Head Tail Lights, Painted LED TBL, Plastidiped wheels, 13" 5% tint strip, 35% tint windshield and front windows, 5% rear tint, Truxedo, Passport 8500, Custom K&N CAI, DSP 91 tune, 18" Magna
Old 03-02-2012, 08:59 PM
Rep:73
Just curious about the recall, Did it mention what the fix was or the cause of the malfunction? I'm guessing a bad ground, bad bulb socket weather boots or E - flasher. (more so the 1st (2) though.
Old 03-03-2012, 05:11 PM
dork's Avatar
Old 03-05-2012, 09:36 AM
Rep:73
Thanks Dork, That's great news for djdavekl & others.
Old 03-05-2012, 08:27 PM
Color: Grey
ABSOLUTELY AWESOME!!! thanks man! now I just to see if they'll honor it in Canada
Old 03-06-2012, 08:20 PM
dork's Avatar
Lol no problem.
Old 03-08-2012, 09:37 PM
Color: Grey
UPDATE!
Truck is going in next week for the repair! It took a bit of digging, but it seems that they are infact honoring the repair
Thanks again!
back seat, stereo, tires
