Old 02-21-2012, 05:57 PM
Ramrob Ramrob is offline
Vehicle: 1999 Dodge Ram 1500 5.9L
Rep:75
Ramrob will become famous soon enough
Default Multiple electrical problems.....NEED HELP!!!!
One day the blower motor didn't work. Any setting... high or low, hot or cold and the heated mirrow button have no power. Weeks later I never touched anything, the radio won't power on. Another week later the dome light, overhead lights and the cargo lights won't turn on. All fuses are good and there is power at the fuze. Any suggestions???
Old 02-22-2012, 12:17 AM
Ramcrew Ramcrew is offline
Vehicle: 2012 Ram 1500 Crew 4x4
Color: Met Dark Mineral Grey
Ramcrew is on a distinguished road
Is your battery good?
Old 02-22-2012, 07:46 AM
Rep:75
Yea, it starts without a problem and drives fine.
Old 02-22-2012, 07:48 AM
Rep:75
I used my circuit tester and probed the fuse slots and they have power. The only other thing I can think of is to check the power at the back of the radio and lights. So I know it's after the fuse box.
Old 02-22-2012, 02:42 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Do you have keyless entry? Or timed curticy dome lights?
Old 02-22-2012, 02:54 PM
black beast black beast is offline
Vehicle: 2000 dodge ram 1500
black beast is on a distinguished road
well the only suggestions i have is check the wiring goin through the firewall. one might be grounding out or something
Old 02-24-2012, 09:27 AM
Rep:75
When I bought the truck I only got the valet style key and no keyfab. I was gonna go through and check some grounds today.
Old 02-24-2012, 04:50 PM
Rep:75
I looked for anything I could and I didn't find anything. I had no 12v batt power behind the radio but I did have 12v acc. I ran a 12v constant to the 12v batt on my radio now everything that didn't work works now except for the blower knobs and heated mirror button. Also the speedo needle is not moving and it did when I bought it. I noticed it when these problems started. Progress.... keep any suggestions coming I would like to resolve the issue still.
Other problems I am having:
Power windows, power mirrors won't work. Worst comes to worst I will run power from the locks or something.
And these:
http://ramforumz.com/showthread.php?p=732440#post732440
http://ramforumz.com/showthread.php?p=732443#post732443
Old 02-24-2012, 06:20 PM
Rep:75
Just noticed that my amp is not on. I found a 12v acc wire in a harness under the driver seat that I tapped into. Don't know what the harness goes to but my remote wire isn't showing any power....
Old 02-28-2012, 08:32 PM
Rep:75
Pulled the column apart and started testing. When I put a 12v acc to one or two of the 6 wires that go in the ignition I finally have heat again. All settings and speeds work now. I found the wire that sends out 12v when the key is turned all the way to the start position. When I get a chance I will run it to the starter wire I have off my push button I'm using now. So i now have a working key and heat. Not worried about the windows because I can make something work. Need to figure out whats up with the speedometer/speed sensor and shift solenoid. A lot of forums have someone with the same problem and they changed out there speed sensor and they still have that problem.
