Old 02-21-2012, 02:08 PM
myf1lthyh4nds myf1lthyh4nds is offline
Vehicle: 1999 dodge ram 1500
Trim Level: sport/off road
Color: flame red
myf1lthyh4nds is on a distinguished road
Exclamation new guy with a slight problem
hey guys im new here my names Brent and i recently purchased a 1999 ram 1500 4x4 sport/off road model with the 5.9 i am not new to dodges as i have had a couple others in the past this truck only has 73,000 original miles and runs fantastic all of the gears seem strong as new except 2nd the other day when i was going up a hill in town it acted like it was mis firing or bucking and today i noticed when i had manually kept it in second it slipped a little when i got on it a little bit but it will not slip in any other gear at all and it also shifts pretty much perfectly like new so dose anyone have any ideas? any information would be greatly appreciated and im glad to be a part of the ram forumz
-Thanks Brent
Old 03-02-2012, 05:48 AM
Color: flame red
:smiley_aag v:
Old 08-01-2012, 12:58 PM
chace.a.lace chace.a.lace is offline
Vehicle: 2000 dodge ram 1500
Color: yellow
chace.a.lace is on a distinguished road
hey i have a 2000 dodge ram with the same exact problem when shifting into second on a up hill, have you figured it out yet? i am trying to diagnose as well.
chace
Old 08-01-2012, 01:18 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
We have a member who's pretty good at explaining what to do with transmissions.
I'll PM his this link and see if he can help...
Old 08-01-2012, 02:20 PM
Dodge Boy13's Avatar
Dodge Boy13 Dodge Boy13 is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: sport
Rep:23
Dodge Boy13 is on a distinguished road
mines automatic 98 and i have the same exact problem! it doesnt seem to be slipping but it bucks and hesitates...ive ran injector cleaner through it and no dice..any ideas?
My Build Thread!!
http://www.ramforumz.com/showthread.php?t=118514
Old 08-02-2012, 10:45 AM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
Hmm sounds very interesting, and that it happens only in 2nd gear. Well the first thing I would do is drop the valve body and check the flex band, it's possible that the band will need to be adjusted and sometimes when they are way out of adjustment the band strut will fall so try adjusting the band, this may help with a slipping 2nd gear, the thing is that it could still slip due to a loss of pressure in the servo due to a leak. The band when applied has aprox 2300-2800 PSI of clamping force so yea... Oh and for those never adjusted a band, the front band adjuster is located on the driver side of the bell housing behind the linkage. You just have to loosen the locknut then tighten the adjuster to 72 inch lbs, back off 3 turns then tighten the locknut to 25-30 ft-lbs. The rear band is the same except you back off 2 turns. The rear band rarely needs adjusting because that band is applied only in reverse and manual 1st. And don't be concerned if you experience a slow WOT 1-2 shift, it's uhh normal and it sucks.
The last thing on my mind is something with the torque converter but like I said last thing on my mind. I would bet money on the band adjustment, if it slips excessively it could cause some engine buckling, the band holds the driving shell stationary thus holding the sun gear stationary and if it slips a little it will slightly lockup the transmission making it a little hard on the engine to turn. If you want to make it almost slip free you would want to upgrade the band lever, the stock lever is either a 2.5 or 2.9, some are 3.X, generally the higher 3's to low 4's are fine, anything higher would be very brutal on the transmission. But you would have to remove the transmission to gain access to the lever shaft plug to be able to remove the lever so is it worth it...
But first try out adjusting the band, I cannot say 100% that will correct the problem but if you tow often and haven't adjusted that band in a while then it's most likely the culprit, even if you don't tow often, if you haven't adjusted that band in long time or never then you can bet the farm on that part.
Tell me how everything goes or doesn't go, if still no good then I can go forward from there. Don't be alarmed if I don't respond for maybe a day or two, I am without internet and have been busy. I have a transmission I'm overhauling so I will be busy for a day or two.
1500, 5.9, ram, trans, transmission
