Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 02-09-2012, 07:10 PM
SEJO's Avatar
SEJO SEJO is offline
Color: Blue
SEJO is on a distinguished road
Default Grill Removal
Hey Fellas,
Does anyone have step by step instructions to remove the grill on the new Rams? I want to remove it and make a few mods and looking for a little guidance before I start...pictures are always helpful if you have some kicking around.
Thanks!
Old 02-09-2012, 07:30 PM
Ram10tuff Ram10tuff is offline
Vehicle: 2010 Ram CC
Ram10tuff is on a distinguished road
Dont have any pics but... Just pulled mine to paint it. There is a plastic cowl held on with plastic push clips. Gingerly perswade these out (about 3/4" round and 1" long with small plastic teeth)I have so i used a body panel fork and remooved mine. After that is removed there are(4) 10?12?mm bolts that will be visable now that cowl is off. After removing them the grill is free..... There are 2 clips on the bottom that hold the bottom in place. If you slightly perswade grill up/outward is will pop right out.
Good luck!!!
Old 02-09-2012, 07:42 PM
APSTRAM's Avatar
APSTRAM APSTRAM is offline
Vehicle: 2012 Ram 2500 Crew Cab 4x4
Color: Deep Cherry Red
Rep:85
APSTRAM will become famous soon enough
Don't forget to use some masking tape to protect your upper bumper cover.
Old 02-09-2012, 08:11 PM
SEJO's Avatar
Color: Blue
OK sounds simple enough....looks like I have a nice little weekend project!
Old 02-09-2012, 10:19 PM
moparornocar72's Avatar
Rep:630
go here, look further down the page.
http://www.ramforumz.com/showthread....ighlight=grill
14.268 @ 95 MPH Full Trim
Old 02-14-2012, 12:36 PM
carlos curiel carlos curiel is offline
Vehicle: 2010 1500 slt dodge ram
Trim Level: slt quad cab
Color: metallic silver
carlos curiel is on a distinguished road
Send a message via ICQ to carlos curiel
Default grille removal
hi guy, Visit one of my threads (front grille info), and Kay9 posted a response to my post, there is a video on the removal of the grille. very informative, good luck , carlos
RamaLam
Old 02-18-2012, 07:24 PM
rambridge's Avatar
rambridge rambridge is offline
Trim Level: SLT - custom..
Rep:19
rambridge is on a distinguished road
this is a pic of my front grill that i replaced.
it was easy. for the installations. take the top fan shroud with the plastic clips.
there should be some bolts under it for the grill. should be 6. then stick your hand down and pull the grill off the clips at the bottom. you will need some force to do this.
Old 02-19-2012, 08:31 AM
FireWire's Avatar
FireWire FireWire is offline
Vehicle: 2011 Dodge Ram
Rep:12
FireWire is on a distinguished road
Where did you buy that grill? Look's great!
My Ram was the only one in the parking lot a year ago when I first got it.
Now there are 4. I need to do something to make mine stand out!
grill, grill removal, remove, remove grill
