Old 09-25-2013, 01:26 AM
richmond richmond is offline
Vehicle: 1999 Dodge Ram
Rep:177
richmond has a spectacular aura aboutrichmond has a spectacular aura about
dvarn, yes it's Emerald Green, from 97 a 2500 5.9L 4x4 gasser. My buyer wanted a 12 valve diesel 2wd, there was 2k to get him to the diesel, so I took his truck in trade. I've been needing something with a bit better clearance for trail anyway, I stuck a photo under Dodge Ram Pictures, so color might show better.
ScoMo, nice 1500 (we now know where the new money flow is........... CANADA) R...
Old 09-25-2013, 01:32 AM
ScoMo ScoMo is offline
Vehicle: 2013 Dodge Ram 1500
Rep:60
ScoMo will become famous soon enough
Haha. Thanks. Alberta oil sands $$$
Old 09-29-2013, 01:32 PM
flyersfan2788's Avatar
flyersfan2788 flyersfan2788 is offline
Trim Level: ST-SXT Appearance
Rep:17
flyersfan2788 is on a distinguished road
My stock '13 CC 4x4.
Took it up an old logging/ATV trail yesterday.
Not much in off-road, but the hill I went up to get there was at least 6" of loose sand and bad ruts, the rears spun out so I had to drop it to 4 low to continue.
Took some pics, and then moved her over a rise near the road to show off some articulation in the coil springs.
Stock tires, may try and upgrade, but they'll do for now, we'll see what fits the budget.....
Old 09-29-2013, 05:25 PM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:329
Nice truck. Beautiful country.
333Half the beast
I used to be
Old 09-30-2013, 04:09 AM
Rep:177
Gorgeous truck. The old diesel I have has Hercules AT II's - Tera Trac. The wide foot print is good for both loads and sand. R...
Old 09-30-2013, 01:03 PM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:55
Wh1t3nukle will become famous soon enough
dvarn, great looking truck. Great tires for sand. Just picked up a trade I intend to put on the trail. R...
I like it! 1500? manual?
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
Old 10-01-2013, 01:20 AM
Rep:177
Default Forgot, de-badged
It's a 97 2500 and an auto (down to 1 leg, so auto is a have to have). But it's got clearance and oil pressures good, compression checked, bearings all good. I'm going through the brakes and giving it a tune up the next two days. Running on 33's R...
Old 10-13-2013, 05:30 AM
Rep:177
Conclusion on the truck I provided in this photo 97 2500 4x4 Emerald green 33" tires on a corrected 3" lift (checked it):
Truck title rcvd. VIN# indicates 8th character as a Z for light duty. It is running 3.55 gearing, with 33" tires, it needs a minimum of 4.10 gearing for off road and light towing (rating 7500 Lbs. 360 V8 gas).
Corrections in progress.....R...
Research.............
Old 10-20-2013, 10:06 AM
h2oman's Avatar
Rep:329
333Half the beast
I used to be
Old 10-20-2013, 10:21 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Mine towing a bay liner,
