Old 01-26-2012, 11:56 PM
Silverstar777's Avatar
Silverstar777 Silverstar777 is offline
Vehicle: 2014 Dodge Ram
Rep:19
Silverstar777 is on a distinguished road
Default I now have 4.56 gears in my 2011 Ram 1500!
Got the truck back today. We had to modify the carrier for the rear axle, but it all worked out and works great! Eventually, I am hoping they will put out a Tru-Trac for this axle, but I am happy for now just getting the lower gears in there.
Old 01-27-2012, 12:13 AM
Rep:2608
I am just guessing, but i think that i read that the 4.11 & 4.56 have LSD
i don't believe there is a OPEN rear end for those gears
Old 01-27-2012, 12:24 AM
Rep:19
For this axle, there are no aftermarket gears available at all. I have the LSD, and there was nothing for it. That's why we had to modify the carrier to work with the gears fromt he previous 9.25 axle.
Old 01-27-2012, 01:11 AM
Rep:2608
If you ever have to pull that hill when it snows or ices over, you will be glad that you have the lower gears
I travel that hill quite often, luckily not under winter conditions
just during wrecks & fog
i use it when going to Barstow, & Vegas & it is a short quicker way to Bakersfield, i so dislike the Grapevine
Old 01-27-2012, 11:55 AM
Rep:19
you're talking about the Cajon Pass? Yeah, it's a pretty tough climb if you are towing.
Old 01-27-2012, 11:59 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
Well Done........................
Old 01-27-2012, 12:39 PM
BJPUSMC's Avatar
BJPUSMC BJPUSMC is offline
Vehicle: 2013 Ram 2500 Mega Cab 4x4
Color: Deep Cherry Red/ Silver
BJPUSMC is on a distinguished road
I was considering this a an upgrade one day so was wondering what all was involved and how much it cost in the end. I have the LSD as well.
2013 Ram 2500 Laramie Mega Cab 4x4,
6.7L H.O. Cummins Turbo Diesel
USMC Pilot
Old 01-27-2012, 03:54 PM
Rep:19
well, first, i would say you need a mechanic that specializes in differentials. The front was no problem. The rear required us to take the carrier to a machinist (in this case, my stepdad) to have the carrier re-drilled to match the bolt pattern for the ring gear. everything else is the same but the carrier bolts and their pattern. Once the carrier was drilled, it was no problem. A few new bearings and it all went together perfect. Total cost including labor and tax was $1540. That's a decent chunk of change, but considering many here would spend $400+ on performance mod's like CAI's or mufflers that will make a slight performance difference, if any, this is a sure way to get a huge performance increase as well as better gas mileage.
and if anyone happens to be in my area, the guy who did the work is Robert Thomas Differential http://www.robertthomasdifferentials...b_page_001.htm
Old 01-29-2012, 12:00 AM
Stuck2theAxles's Avatar
Stuck2theAxles Stuck2theAxles is offline
Vehicle: 2010 Ram 1500
Trim Level: SLT BigHorn
Color: Gray
Rep:108
Stuck2theAxles will become famous soon enoughStuck2theAxles will become famous soon enough
what did you do about you speedo and what not ?? did it not mess anything up ?? cuz i have a 12 i want to put gears in and i will do just about anything to get em in there but i thought it would totally mess up the shift schedule and everything since i dont have a programmer
2011 CCSB Sport 2WD - McGaughys, FOOSE , shaved clean and newly added DIABLO SPORT !!
2012 CCSB Lone Star 4WD - McGaughys , KMC, shaved clean
2012 CC 2500 Cummins - Thuren, Fox , H&S w deletes upstairs and down
Old 01-29-2012, 12:02 AM
Rep:19
The shift pattern was messed up just from changing to 35" tires. However, when I did the gear change, I also got a hypertech speedo calibrator. Input the new gear ration and tire size, and now it shifts perfect.
