Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - News Desk > Newbie Checkin!
Newbie Checkin! New to the forums? Introduce yourself here!
Old 01-15-2012, 06:34 PM
GPMOPAR GPMOPAR is offline
Vehicle: 1999 Dodge Ram Sport
Color: Yellow
GPMOPAR is on a distinguished road
Coil resistance is low but improved after I removed it and let it warm up. It probably needs to be replaced again. After re-installing it, still nothing!
I traced and checked the ASD relay and related fuses...all appears to be okay. This one's got me stumped so far.
Old 01-16-2012, 02:49 PM
AutoAnything's Avatar
AutoAnything AutoAnything is offline
Your Mod Superstore!
Vehicle: Full Garage!
Rep:165
AutoAnything has a spectacular aura aboutAutoAnything has a spectacular aura about
Hello and welcome!
Click the ^banner^ and save up to 16% OFF Orders Above $150 on Dodge Ram mods.
We price match, simply call 888-591-8563 or
Click-Here-to-Chat and we'll beat ANY price by $1.
Click Here To See The Latest and Greatest Specials From AutoAnything!
Old 01-17-2012, 09:13 AM
Color: Yellow
okay...there's no spark. New coil has no spark so the trail ends at the PCM. Without a DRB tool, I'm SOL. I'll go over all of the connections and grounding but I'm sure nothing could have come loose. The cold is likely not a factor as the temp rose above freezing yesterday and it still wouldn't start. All thoughts on this are welcome!
Old 02-06-2012, 09:30 PM
Color: Yellow
Turned out to be the CKP sensor afterall. The new sensor wasn't bent quite right and caused new problems when the engine warmed up and the flywheel starting rubbing against the sensor causing errors 0340 & 1391. Removed it, bent it away from the flywheel and reinstalled although the grommet is missing. Problem solved...what a pain.
Old 02-06-2012, 10:17 PM
moparornocar72's Avatar
Rep:630
Welcome to the Forum from Auburn, AL! Hope your liking it so far! You should find a lot of useful tips and information on this site as well as many MODs. If you should have any question, try using the search function at the top of the page in the menu. If you can’t find an answer to your question, by all means start a thread with your question. Enjoy the Site and we’ll see you around the Forumz!
14.268 @ 95 MPH Full Trim
Old 02-06-2012, 11:55 PM
infinit06 infinit06 is offline
Vehicle: 2010 dodge ram
Color: Orange
infinit06 is on a distinguished road
hello and welcome
5.2, cold no start, timing issue?
