Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - News Desk > Newbie Checkin!
Newbie Checkin! New to the forums? Introduce yourself here!
Old 01-14-2012, 03:37 PM
GPMOPAR GPMOPAR is offline
Vehicle: 1999 Dodge Ram Sport
Color: Yellow
GPMOPAR is on a distinguished road
Default 99 5.2 won't start
Had my truck for 10 years now and love my Ram but lately it's been a pain. I found it had bad sp wires so it was time to replace them. Unfortunately, to replace the cap meant replaceing the distributor since the bolts seized. I put this off for a few years but decided to bite the bullet and do it. Not being in a convenient place like my old 440, I pulled the intake, etc. Long story short, all back together with a used dist. (marked the dist position) it started and ran fine. Test drove with no problems at all! Today, the temperature dropped but not crazy cold, it cranks fine but won't even try to start. This has never done this in the cold before aside from previous issues with the plenum pan, O2 sensor, etc. I can't imagine a sensor suddenly failed and the fuel pump sounds like it's working. I suspect the timing could be a cause but it ran fine a week ago and I can't imagine the timing being off a fraction of a degree would prevent it from even trying to start. I know it's probably spark or fuel but I'm stumped. Coild was replaced a year ago so I ruled this out... any thoughts? It's got me in the mood to build up a 5.9 and retire the 5.2 w/245k...
Old 01-14-2012, 03:45 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
Hello and welcome to the Ram Forumz the coolest and most informative truck forum on the net!!!!! Please take a minute to post some pics of your truck. Have you added any modifications or are you considering any? If you need any help with navigating the forum CLICK HERE or click on my name and leave me a message and I will do my best to help you On behalf of the staff let me thank you for joining and we all hope your stay is awesome, We look forward to learning from you and helping you!!!!!
See ya on the boards!!!!
Old 01-14-2012, 05:02 PM
Rep:4072
Hello and welcome to the forum, glad to have you join us! Sorry to hear about your problem and sounds like you've already been over what I would think to check so hopefully someone will be along soon with some good advice for you! In the meantime, best place to post that question is here: http://www.ramforumz.com/forumdisplay.php?f=172 but good luck and be sure to keep us posted! Lots of great people and info here, so any help you need, just ask and I hope you enjoy the site!
Old 01-14-2012, 05:21 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
Welcome to the Z! Nice to have you with us!
Is it throwing any codes? If a sensor did die on you, you should be seeing the check engine light. Check your battery. My old 99 Dak did this to me once, it would crank decent but just wouldn't run to save it's life. I threw it on the battery charger and boom ran like it should.
Try boosting the battery. On all these trucks if the battery falls below a certain voltage the damn things will crank but not run. After that then it's back to the basics, fuel, spark then timing. With the colder weather your cold cranking amps will fall off, could be enough to make the ECU grumpy. Let us know how you make out.
Big Red my old 2011 Sport
Old 01-14-2012, 05:23 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Hello and welcome to the Z, glad to have you aboard. I would have it scanned for codes and go from there. Is the MIL light on ? Have any pics to share please post them up, enjoy the forum.
Old 01-14-2012, 07:27 PM
old hot rod's Avatar
old hot rod old hot rod is offline
Vehicle: 2010 Dodge Ram 1500 4x4
Rep:386
old hot rod is just really niceold hot rod is just really niceold hot rod is just really niceold hot rod is just really nice
Send a message via Yahoo to old hot rod
Welcome to Forum Z
Great to have you with us!!!
Hell Bent Steel Leveling kit, K & N filter, Tinted Windows,
Mufflex DOD18M, Mopar Intergrated Trailer Brake,
DiabloSport Predator (U7137) 180 Thermostat, WeatherTech Vent Visors
DiabloSport Catch Can (C-1040)
Old 01-14-2012, 07:40 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3944
Hello and welcome!
Good to have you with us, I hope you enjoy the board!
Old 01-15-2012, 12:39 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Welcome to the forum,
This forum is full of great looking trucks; packed with great mod ideas and there are loads of knowledgeable and experienced people here.
with Stump3r. Put a battery charger on it to bring right to the top, then try it. If it starts, it's new battery time.
AND - We all like pix! Got any to share?
Enjoy the Z!
brad
Interested in one of my mods?
Old 01-15-2012, 11:11 AM
Color: Yellow
Thanks for the quick replies. These forums have saved me lots of money over the years.
The battery is fine as I keep it on a trickle charge like my sleds and boat. No codes unfortunately and there is plenty of fuel pressure in the fuel rail although I need to get a gauge and check it.
I woke up this morning thinking about it and I'm going to check the coil anyway. I remembered that the coil resistance changes with cold temperatures and a weak coil will not supply enough voltage in the cold. I'll let you know what I find since it's cold again today. Might be time for a new Ram!
Old 01-15-2012, 04:58 PM
RAMTX's Avatar
RAMTX RAMTX is offline
Vehicle: 2012 Dodge Ram Crew Cab 4X4
Trim Level: Lone Star
Color: Bright Silver Metalic
Rep:110
RAMTX will become famous soon enoughRAMTX will become famous soon enough
Welcome to the forum Z, nice to have you here!!!!
__________________________________________________ ___________________
__________________________________________________ _____________________ K&N drop in Air Filter - Tonno Pro Tri-Fold Bed Cover
5.2, cold no start, timing issue?
