Old 01-11-2012, 10:43 AM
Christo360's Avatar
Christo360 Christo360 is offline
Vehicle: 2012 Dodge Ram 3500 Dually
Trim Level: Longhorn Laramie
Color: Black/Gold Trim
Rep:19
Christo360 is on a distinguished road
Default 6" Lift for Dually Help
Ok, I hate to have a redundant post but I've honestly put a lot of effort in trying to figure out what kind of leveling kit and 6" lift kit to use for my 2012 3500 Dually. I've had minimal success mainly due to not many people lifting a 3500 dually and 1000's of threads and responses to sort through. I would very much appreciate suggestions for this project. My main criteria would be:
-Respectable high quality and durable brand.
-Installation does not require any extra miscellanous purchases.
-The tire size I plan on using is a 37x13.5x22 Nitto Trail Grappliers.
-Airbags is also an option to achieve 6" lift.
Thanks to all who chime in.
Old 01-11-2012, 12:47 PM
Rayne's Avatar
Rayne Rayne is offline
Rep:73
Good lord that thing is going to be massive if you go through with that. :O
Old 01-11-2012, 01:18 PM
Schmitz's Avatar
Schmitz Schmitz is offline
Vehicle: 2005 Dodge Ram 2500 4x4 QC LB
Schmitz is on a distinguished road
Just about any lift for a 3/4 ton will fit your 1 ton the biggest problem is the u bolts I believe I dont think the ones in the kit will fit a dually rear end you will most likely have to purchase them separate keep in mind you will most likely need wheel spacers to space the duals apart also
2005 Dodge 2500 4x4 QC LB Hemi, 6 inch lift, 37" Cooper Discoverer STT's, Bully Dog programmer, K&N cold air intake performance throttle body, true duals, debadged.... Soon to come 4.56s and wheels, maybe more lift.
1980 Chevy K20 4x4 9 inches of lift 37" Boggers, 402 BBC, 4 spd, D60, 14ff.
2012, 6" lift, dually
