Old 01-08-2012, 10:19 PM
Bjoseph24 Bjoseph24 is offline
Vehicle: 2011 Dodge Ram
Trim Level: Lonestar
Bjoseph24 is on a distinguished road
Default RES 130 Radio Uconnect issue
i have a 2011 dodge ram, with the "130 res" radio (it has the uconnect buttons and sirius radio) but, it did not come factory installed with uconnect but the dealership installed it for me (so i dont have a usb port in glove box/concole or on radio). when playing my iphone through bluetooth it sounds like chpmunks. is there a way i can update my radio/uconnect since i dont have a usb port? the dealer aparently cant figure it out. any help would be great. is there a way to update the radio/uconnect my cd?
thanks!
Old 01-09-2012, 01:59 AM
Rep:2616
all i can do is point you in the right direction
the reading is up to you
http://www.google.com/#hl=en&cp=40&g...w=1024&bih=550
Old 01-09-2012, 09:28 AM
Al E. Gator's Avatar
Al E. Gator Al E. Gator is offline
Vehicle: 2014 Ram 1500
Color: Deep Water Blue Pearl
Rep:30
Al E. Gator is on a distinguished road
The uconnect box has a port for the USB cable to plug into and Dodge sells the cable. Your dealer's mechaniics are idiots if they can't figure that out. The installation instructions for the uconnect even address the cable. There are 2 different part numbers for the uconnect box and I think the cables are different but you should have been given the newer box with a standard USB connector on it. I did my own install and used a standard USB cable with a gender changer. It works fine.
Old 01-09-2012, 10:15 AM
RAMTX's Avatar
RAMTX RAMTX is offline
Vehicle: 2012 Dodge Ram Crew Cab 4X4
Trim Level: Lone Star
Color: Bright Silver Metalic
Rep:110
RAMTX will become famous soon enoughRAMTX will become famous soon enough
You need a cable, that all. Hope this will help.
http://www.ebay.com/itm/CHRYSLER-Mop...item45ffa32965
http://www.ebay.com/itm/Dodge-Ram-iP...item5647ebc32c
http://www.ebay.com/itm/CHRYSLER-RER...item45f7094d02
__________________________________________________ ___________________
__________________________________________________ _____________________ K&N drop in Air Filter - Tonno Pro Tri-Fold Bed Cover
Old 01-10-2012, 03:34 PM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
Hello, The Uconnect main module is probably going to be wire tied to the dash near the glove box. Drop the glove box down and you should see the module pictured below. For some reason Chrysler parts offer the Ipod / USB cable as an optional cable to the Mopar accessory Uconnect kit. It is needed not only for playing (and charging the iPod or iPhones thru Uconnect) but also for any Uconnect SW updates.
You mentioned the choppy audio sounding like "the chipmunks. What you need is what the dealer should have been able to tell you as well as perform for you. There is a TSB 08-036-11 rev "A" that has been available since Oct 26th 2011. This is a revised TSB based off of #08-036-11 that was released on June 29th 2011. The revision has nothing to do with the SW but actually extends out the supported vehicle build date from April 18th 2011 (vehicles built prior to this date) to June 1st 2011. It also rewrote a few steps of the instructions. The original instructions were longer and some of the techs wouldn't read it all which caused them not to perform the update correctly in some cases.
The iPod cable is PN# 82212160 and it will plug into the small connector on the module, then run to the glovebox.
If you would like to PM me with an email address, I will send you the update file and instructions to perform it. It's not a difficult task. If you can download a file to a thumb drive, then you can do this. The update will take about 20 minutes.
I hope this information is helpful.
thanks!
bluetooth, radio issues, uconnect, update
