Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 01-03-2012, 09:15 PM
pALErIDER's Avatar
pALErIDER pALErIDER is offline
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
Rep:12
pALErIDER is on a distinguished road
Question Won't Start
Hi guys,
I have a 96 Ram 3500, 12v 2nd Gen 5.9L Turbo Cummins.
Plugged in last night went well below 0C... close to -20C, fired it up this morning no problem... ran for about 15 minutes then quit before it was warmed up.
I tried to start it again, it seems to start but quits within 1 second, new fuel filter installed, Howes conditioner used faithfully, then I noticed when I turn the key to "on" position there is no "Wait" or "WIF" light only parking brake and seatbelt lights, also the guages don't "cycle".
I'm guessing computer.. PCM or ECM??? where is it and how do I check it?
Any ideas?
I have had the guages go "dead" while driving in the past for short periods then begin working again...
Old 01-04-2012, 08:58 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Can you hear lift pump cycle?
Old 01-04-2012, 09:35 AM
pALErIDER's Avatar
Rep:12
No I don't hear the lift pump cycle.
Old 01-04-2012, 10:32 AM
pALErIDER's Avatar
Rep:12
Default New Development
ok.. so I got it running after discovering the 10 amp fuse in the #9 position that controls the lift pump, ECU/PCU, etc. was blown, but it keeps blowing after about 10 minutes of idling...???
Bad relay, or ground???
Old 01-04-2012, 06:07 PM
pALErIDER's Avatar
Rep:12
Thumbs up Solved!
After checking the ground, battery terminals, the intake heater relays, intake heater, and all the relays in the power distribution box, I focused on the "Fuel Shutdown Solenoid" and "Fuel Shutdown Solenoid Relay". the relay was an easy check... but the solenoid was a bit of a p.i.t.a! I had to get a buddy to watch it while I cranked the engine... and it would not retract! if I depressed it manually it would hold in the "on" position but it would not retract itself!
On closer examination I could see separation with the epoxy seal and obvious corrosion/oxidation underneath.
$850.00+tax OUCH!!!
Swapped out the solenoid and all is good!!!
Old 01-04-2012, 06:47 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I'm glad to hear that you found the problem.
Better yet. I want to thank you for posting the steps you took to rectify the problem. It makes it much easier for other members to trouble shoot their trucks.
Once again...Thanks.
Old 01-04-2012, 06:58 PM
pALErIDER's Avatar
Rep:12
Smile Your welcome!
I didn't want it to appear as another asked but unsolved question...
It's easy to ask a question... answers can be hard to come by, and it was by reading similar threads that I was able to narrow my search and eventually find the problem!
I hope this thread helps narrow someone else search or better yet answer a question!!
Old 01-04-2012, 07:36 PM
ramfam's Avatar
Trim Level: Base
Rep:21
Glad you got it solved, eletric grimlens suck
3500, 5.9, computer, pcm, won't start
