I tried to install my hids tonight, put everything in the driver side and tried it to see if it work and it did. After that I closed everything up and turned the lights on again just to make sure and the hid didnt light up so i took everything apart to check my connections again and still nothing. I tried my halogen to see if it worked and nothing. So my driver side low beam and high beam dont work anymore but the passenger side is fine. I need headlights in the morning. I need help asap. I have a 2010 with quad lights.
:4-dontknow:Well if you figure out what the solution is send me an email cause I have the same problem except it is the passenger side. I looked for a burnt fuse and can't even locate the head lamp fuses in the box so I think it might be a hidden relay somewhere. My email is don_pr2003@yahoo.ca.
Thanks, I checked it out everything is good. Any other solutions? I still have the same problem. I looked through this forum last night to see if anyone else went through this and could never find the solution.:4-dontknow:
