Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Old 12-16-2013, 05:57 PM
fever42 fever42 is offline
Vehicle: 02 dodge ram 1500
fever42 is on a distinguished road
Default Towing mpg
I get around 10 with my 7k 5th wheel ,changed my injectors to ford 19# 4hole and now i get 12/13 on same trip. Going to add a CAI this weekend and see if i can around 14 hope so
Have a nice Christmas and Happy New Year
Old 04-28-2014, 06:59 PM
hoovie87 hoovie87 is offline
Vehicle: 2007 Dodge Ram 1500
Color: Black Metallic
hoovie87 is on a distinguished road
I have a 8.5x16 ft with 5' V-nose cargo trailer at about 5,000lbs. I get anywhere from 8.5 to 11 mpg depending on the speed and traffic. Usually average 10mpg. I have a cold air intake and a vivid linq.
Old 07-30-2014, 03:19 PM
gotursix gotursix is offline
Vehicle: 2003 Ram 1500 SLT Quad Cab
gotursix is on a distinguished road
Default Thought it was just me
Well, I feel a LITTLE better after reading these. I just joined this forum and the only reason was to try to get advice on how to improve my mileage while towing my camper. 20' TT @ 4500 lbs. I'm getting 5-6 mph!! It's a 2003 SLT Quad Cab with a 4.7. Everything is stock. Somebody told me a K&N air filter might help. I'm seriously thinking about buying a 2500 just to tow this thing because i HAVE to get better than 5mpg. It takes all the fun out of camping if I have to spend $300 on gas to go less than 400 miles round-trip. Is there ANYTHING else I can do?
Old 07-30-2014, 04:08 PM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2549
Originally Posted by racecar67 View Post
I get between 9-13 pulling a 7000# TT with a 3.55 rear.
I now have a new TT since my earlier post and like you I am now pulling approximately 7K, maybe a little less with 3:55 rear and I am getting identical results as you.
Old 08-03-2014, 05:22 AM
DodgieDan DodgieDan is offline
Vehicle: 2003 Dodge Ram 1500 Quad Cab
DodgieDan is on a distinguished road
I am pulling a TT that goes just around 6600 lbs. loaded for a trip. Prior to having the Transmission completely overhauled and a shift kit put in it I was lucky to get 9.5 miles per gallon. Have been on 2 trips now with the rebuilt tranny and getting 11.5 to 13.5 per gallon depending on terrain. I live in BC can be very hilly at times. Oh by the way that is with a 3.55 rear end.
Old 08-14-2014, 01:45 PM
MelbaToast's Avatar
MelbaToast MelbaToast is offline
Vehicle: 2006 Ram 1500 Big Horn
Trim Level: Big Horn Edition
Color: Atlantic Blue
Rep:36
MelbaToast is on a distinguished road
Just finished a 400km round trip with 5 adults, bed of the truck loaded with gear and a 4300lb Travel Trailer also loaded with water and food inside. Averaged 12.5mpg, mostly highway with one section of back roads that is 10% grade up and down for about 1km each way.
Old 08-31-2014, 12:08 AM
rbaker4401 rbaker4401 is offline
Vehicle: 2008 Ram 2500
rbaker4401 is on a distinguished road
I get in the 13s just driving around. I can pull my 5k+ tandem axle boat and trailer and stay in the 12s in hill country
Old 09-13-2014, 11:30 PM
BayeandPruitttrans BayeandPruitttrans is offline
Vehicle: 2005 Ram 3500
BayeandPruitttrans is on a distinguished road
I pull a 43ft flatbed gross weight 26k. From Tenn to Colorado to Texas I average 9. With the 5.9
Old 11-24-2014, 02:17 PM
Maz94protege Maz94protege is offline
Vehicle: '14 1500 Express 4x4 dbl cab
Rep:29
Maz94protege is on a distinguished road
Ive heard a few owners complain about the 4.7 with towing, its a good motor, just not as powerful for towing as the 5.7 is. What year is the trailer, the older trailers (lets say early 2000's and older) weight more than the current models do at same length/configuration. Check your trailer brakes and tire pressure. Might be able to get some lower resistance rolling tires for the trailer to help.
Few things you could do to the truck:
1. Intake and Exhaust (may help open her up a bit)
2. Rear end change
3. Computer program
4. Use 89 Octane (sometimes this helps)
I'd hate to hear you replace the truck cause of the trailer...some people keep the truck and get a newer trailer because they are lighter. All depends on finances and how attached you are to each.
Have you checked the Trailer Empty and loaded weight in comparision to the VIN/RV sticker? Maybe lighten the load inside the trailer...
Just compliling ideas while im bored here at work,
Hope this can help.
