Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 11-02-2013, 09:47 AM
River7rat River7rat is offline
Vehicle: 2011 Ram 2500 Laramie
Trim Level: laramie
River7rat is on a distinguished road
Default 2011 2500 Camber out of spec
Has anyone else had problems with the camber on their truck being out of spec? I recently had the wheel alignment checked at an independent shop. The camber is out of spec. The only way to correct the camber is to install offset top ball joints. The truck has only 50k km and is all stock. The mechanic said there is no way a truck with only 50k km and good ball joints should be out of spec. He has seen this a couple of other times and suspects the axle tube coming out of the differential is bending a little to put the camber out.
Old 11-02-2013, 10:39 AM
Color: green
Rep:632
i would try a different shop to see what they find. i have not heard of this.
Old 11-04-2013, 09:34 AM
Trim Level: laramie
This was the second shop that checked it. The first was at Kal Tire. I put new tires on and they checked the alignment and told me the same thing. the camber was out of spec and they would have to change ball joints to fix it. I have it booked into the dealer next week, so will see what they have to say.
Old 11-29-2013, 05:35 PM
spiderbob spiderbob is offline
Vehicle: 2013 Ram
Trim Level: Bullhorn
spiderbob is on a distinguished road
I also have been told that my front end is out of spec, by a reputable frame and alignment shop here in Southern California. They said they average two Ram Trucks a week where they change out the ball joint, as the stock is not adjustable. I'm going to take it in next week as I only have 2,000 miles on it and see what they say. My truck is a 2013 model 2500HD diesel.
Dodge Ram 2013HD Diesel 4X4 with snow plow package
