Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V10 Specific Topics
Old 04-23-2014, 04:35 PM
dabranco dabranco is offline
Vehicle: 1996 dodge ram
Color: red
dabranco is on a distinguished road
So got the motor home it is now torn down piston number 9 has a hole in the center, front main bearing is grooved along with some light grooving on the crank cylinder bores appear to be fine, cam bearings and center 2 main bearings are down to the brass, also oil pick up tube also has small chunks of aluminum in the screen all lifters and cam appear to be in good shape. Thought I would give an update. Also at some point this motor had a supercharger on it.
Old 06-02-2014, 10:42 PM
440RC86 440RC86 is offline
Vehicle: '96 Ram 2500 V10
Color: green
Engine: 2003-2003 488ci (8.0L) Magnum V10 310hp 450lb/ft
440RC86 is on a distinguished road
Are you talking 4x4?
Old 02-16-2015, 09:51 PM
Color: red
2wd kinda on the back burner for now due to cut backs at work
