anyway i could fit 35 toyos on 22 rockstar 2s,, which offset would i have to choose that would cause less rubbing or if i would need spacers to stop rubbing,,,
Well the first thing you do is narrow down the ones that will work for the bolt pattern on your truck which is 5 on 5.5 (139.7mm). That leaves us with RS2 22-95 5:1397 12ET BLACK 62.0 $ 396.00 based on the list you got. I'm sure they have more sizes than just that.... so what parameters are you putting in for it to search for? I'd recommend going directly to KMC's website and finding their full list of the Rockstar 2's. Don't put any search parameters in regarding your truck or it might limit the list to what it thinks will fit on a stock truck (like what I think the Tread Depot site did).
Hmm... well apparently they only make them in a 22x9.5 +12 offset with a 5 on 5.5 bolt pattern.
Theoretically you should be able to run 35x12.5 Toyo MT's on those wheels with a leveling kit however it's going to be really tight. It's possible that you'll need 10mm spacers to give you a bit of extra clearance on the upper A-arm.
alright so you think that size will work with 35 toyos ? and how much would they stick out stance wise ? i want a wide stance i think it looks pretty sickk, but would there be any rubbing ?
I was thinking of lifted my truck and stuff before but i dont want to spend that much money,,do you think these rims with 35s would look good ? i was thinking of painting the removable spokes mineral grey too if i were to buy them.
As I stated above they're going to be very tight with 35x12.5 Toyo's because of how wide those tires are when mounted.
They aren't going to stick out very since they're positive offset rims. You're looking at an 1" or so past the fender and if you have flares they'll cover them completely.
Rim taste is completely different from person to person... so base it off your opinion not others. Personally I'm not a fan of Rockstar wheels at all but that shouldn't affect your decision on buying them or not. But if it were me I'd be choosing different wheels simply because the Rockstar 2's don't come in the size/specs to achieve the look you want.
alright sounds good, what would be the best size for my truck,,, and i hear alot of people get -12 offset how much would -24 stick out, and would flares cover them dont want to end up with rock chips on the truck...even though i like the look without flares but might get inspected then..
I have a leveling kit and 35x12.5x20 Mickey Thompson Deegan 38 on Rockstar 2 wheels (offset 18) and 1.5'' spacers.I'ts just perfectm but when i turn the wheels to the extremity the tire touch a little bit but it's good ! I love it
