Hi I just joined the forum and have a question that's probably been asked a hundred times. I have yet to find an answer so hoping someone can help me here. I have a 2014 Ram with a mcgaughy 2/4 drop kit sitting on 22 inch viper replicas. I had a local shop do the job for me and just wondering if they did it right because i notice that it has a slight rake in the rear. Around an inch and a half higher. Is that normal? Plus I notice the ride is a lot rougher. Again is this normal? Thanks
The rake should only be about 3/4" but if it was just done the springs need time to settle, you can also take a look at where the rear coils are sitting on the lower cup, I could get 1/2" difference just be rotating the coil because of the way it sat on the lower perch. Rougher ride is because of the shocks with a smaller sidewall, very typical. Shock upgrade normally makes a big difference.
You didn't say if you have the deluxe or eco kit (front springs or spindles). I have the deluxe kit on my 13 and have about a 1 inch difference. I think they use the same rear springs for all of the Ram kits, so the lighter regular cabs don't get as much drop as a heavier quad cab would. Mine settled to right at 3" drop in the rear. You could always cut a little off the rear springs if you want level.
thanks for the input, I went with the economy kit. I didn't even know there was a deluxe kit until after I had the current kit installed. I am thinking of going with belltech street performance shocks and hellwig front and rear sway bars. I recently had an mbrp exhaust black exhaust and a vararam intake put on though I can't really feel the difference.
Related Threads
DODGE RAM FORUM
2.2M posts
201.9K members
Since 2008
We’re the ultimate Dodge RAM forum to talk about the RAM 1500, 2500 and 3500 including the Cummins powered models.
