Well after 2 weeks using a 2012 airaid cai, on 2013 i thought i would take it off and try the s&b because i didn't like the fit of the airaid as they havn't made one for the 2013 yet. As my personal feeling i didn't notice any change from stock intake with the s&b and ended up putting the airaid back on. Just my input.
i do however like the security of s&b being enclosed
There is minimal differences between all the so-called CAIs. Their biggest benefit is from the less restrictive filters compared to stock. The systems that will give the best results are the ones that will bring the coldest air possible into the intake tube, so the vararam or any with a power scoop in addition to the regular intake. Sealed or not won't make a huge difference when driving around, but you'll see a difference in IATs when idling or slow cruising with a sealed intake.
You don't need to 'ram' air in to make it better, with a naturally aspirated motor you just need to allow it access to the coldest air possible with the smoothest transition possible. Most ram air systems are only good above 80km/hr, below that you don't see any gains, so access to a colder air reservoir is more of a benefit for most driving.
Stock system is a cold air intake. I dont know of any ram air systems that draw in hot air. Since I drive quite frequently over 49.7 mph (especially at the track), I would see it as beneficial. Might be splitting hairs, but ram air intake is as good as it gets, short of a supercharger.
to a point i agree, however punching it of the line now versus befor their is a difference, less lag at take off and it runs way better. Yes cold air is important but so is more airflow.
^ I can believe that when comparing to stock. I was referring to the difference between Airaid and S&B. That difference would be sound unless someone can prove otherwise on a dyno or time slips.
I'm personally a beleiver in intakes. I don't have one on my truck as of her, but my previous car I gained 4 tenths and 3 mph in the 1/4 mile. That was with a k&n short ram intake
Related Threads
DODGE RAM FORUM
2.2M posts
201.9K members
Since 2008
We’re the ultimate Dodge RAM forum to talk about the RAM 1500, 2500 and 3500 including the Cummins powered models.
