Need help with this code..
6K views 6 replies 5 participants last post by  GTyankee
#1 ·
I was driving around last night when out of nowhere I noticed my truck felt like it was stuck in first gear... I plugged in my superchips amd I got this b2215 fcm internal code.. I disconnected my negative battery cable for a little bit to see if that would help but once I turned my lights on the issue came back.. I thought it was a short in my hid harness but I checked amd they are fine.. Any ideas what's wrong or how to fix it?? I have an 07 1500 5.7 if that helps..
#2 ·
Take it to the dealer, I think there are TSBs for this. Dealer will fix free.
#7 ·
not sure if this is the cause
2006 TSB
TSB 08-021-06
TIPM Flash - Diagnostic Trouble Codes B178C, B166E, B2215
For Trailer Tow Lamps Inoperative Indicating Short Circuits In The Wiring
On The Trailer Or P1277 For No Crank - Starter Solenoid Current Excessive.
B2215 - Internal Fault - An Internal Fault code counter has exceeded its limit and an output is disabled.
