This is a NEW JBA part that is in stock and ready to ship. You guys wanted a stainless header that did not break the bank so here it is.:rck:
There is no mistaking that the 5.7L Hemi has first class power in the truck and SUV market. JBA's new Stainless Steel 1 7/8” Long Tube Headers for this awesome power plant have been engineered to deliver more of that power throughout the RPM range where it can be put to good use. Any truck owner can tell you that low-end torque comes in handy when hauling or cruising. Mid-range power when charging a hill or passing on the freeway rates high on the wish list too. JBA addressed both of these areas and added an extra 30+ hp to the peak power as well. How does an extra 24 lb-ft. @ 2100 RPM sound? You have plenty of options to suit your needs as well - "works" finish stainless steel or high heat rated ceramic coated.
Features
• 3/8" thick laser-cut flanges
• Firecone® technology collector
• One piece CNC Mandrel-bent stainless steel 1-7/8" primary tubes
• JBA sealing rings on head flange
• Premium quality hardware included
• 02 Extensions Included in kit
• Optional ceramic coating (thermal barrier)
• 360 degree Tig & Mig welds
• Oversized exhaust ports
2009-2014 Dodge Ram 1500/2500/3500 5.7L Hemi 2&4WD
6961S
Jobber $599.99
http://images.pertronix.com/Exhaust%20Products/JBA%20Exhaust/6961S.jpg
6961SJS
Jobber $737.99
http://images.pertronix.com/Exhaust Products/JBA Exhaust/6961SJS.jpg
6961SJT
Jobber $737.99
http://images.pertronix.com/Exhaust Products/JBA Exhaust/6961SJT.jpg
This header kit come with reducers so you can hook them up to the factory Y-pipe or we will have a couple different options on Y-Pipes in the near future. Parts are already in stock at Moe's Performance or your favorite retailer.
