42" Curved LED Bar in 2013 Sport Bumper
19K views 38 replies 28 participants last post by  Hollow19
#1 ·
This is a test fire of it, I plugged it into the foglight
Very tight, I might add a few washers to bring it a bit further out.
See less See more
6
#3 ·
Thanks!
  • Like
Reactions: Bushmaster
#4 ·
Very nice I wish the Outdoorsman had the cut out like in your bumper. Looks like it belongs there.
I will give you some rep points for that.:smileup:
#5 ·
Thanks. I will wire it up properly tomorrow.
#7 · (Edited)
The front surface?
Yes I can definitely do that.
Actually this is an Ebay special, I paid $220. I can buy 4 for the price of one Rigid.
It is 1050mm, or 41" 3/8 inches
#9 ·
Headlights only
Headlights/Fogs
Headlights/Fogs/LED bar
LED Bar only
Headlights are 55w HID
Fogs are 35w HID
#13 ·
Good thread like how you included output shots. Can you pm the ebay seller u got it from? I'm guessing u just got it recently, how is the quality and have you had any water or moisture issues? Did you use mounting hardware included or something else? Great job!
#15 ·
No cutting of any factory parts. I simply took the lower valance plastic out.
Customization: I bought a 10ft piece of 1/8" x 1.5" Aluminum and mounted it.
Seller is 2007gg
No moisture ingress/moisture in the lens so far.
The bar was a lot heavier than I thought it was going to be, seems like a solid bar. No complaints so far.
I made the brackets myself out of 1/8" thick, 1.5" wide aluminum
I unfortunately didnt take any shots of the mounts themselves. But they were ridiculously easy to make
#17 ·
Wiring was very straight forward. I installed a relay directly to the battery, running to a switch in the cab (which I will be swapping out for something from http://www.otrattw.net/).
Once I get that switch in I will run it off an ignition source. Right now its 100% independent and straight to the battery.
Relay harness came with a fuse, etc
Took me 10 minutes to wire/solder connections.
#19 · (Edited)
I have the same 42" curved 240 watt spot/flood on my 14 express. Mine sits a little further in so I could put tht stupid front plate bracket back on. Also from ebay from led factory direct out of Cali. For $165. I used them since I have mounted their straight bars in friends trucks and never had a issue. Probably all made in the same Chinese factory anyway. I don't buy rigid. They are expensive and these work good enough for me. I just used a 40 amp relay on mine incase I want to add some small pods or something later with a ground trigger switch to save from having to add extra inline fuses for everything. Looks good. I was lazy and got some brackets off a guy on another forum he had water jet cut and drilled so it was a 30 min install with wiring.
#22 ·
Mounted up the same bar after seeing yours. Brackets rusty, just got it put on, and last minute changed the steel from what I had already painted, getting late on a sunday figured I'd wait until spring to pull it and paint it
#23 ·
Those are some nice looking brackets.
I might have to get some fabricated at work
#25 ·
Cut with a plasma, the drivers side just made it, ran out of steel and wanted it to grab the two frame bolts, the passenger side light bar bolt is more centered.
#26 · (Edited)
I have the same setup in my 14 express. I left mine recessed so I could keep the front plate on since it came with the bracket and don't feel like filling the holes and repainting the bumper. Later when it gets chipped up I will probably remove and fil it in then paint it. Wish mine didn't already have a plate holder on it. Luckily someone had some water jet cut stainless brackets made for their 12 and had extras made so I didn't have to make any.
#32 ·
I plan on doing the same thing when i start modding my 2016 Ram 1500 Big Horn, that i have not ordered yet.
First will be switching out the Chrome bumpers for the Express/Sport type painted bumpers
Then Tow Hooks & curved light bar installed in the front bumper
