Hi,
Once every 2-3 months or so I will start my truck at work and put in gear-after putting in drive the engine will idle up and it will pull against the brakes and die.
I will start again out of neutral and it will run fine. Otherwise truck runs great.
Truck is 06 1500 SLT w/4.7L motor and 97K. It has done off an on for a couple years. I have owned it since new, has fresh Champion copper plugs. I've cleaned the throttle body and and IAC at each plug change.I do maintenence myself-tranmission nver flushed, but had two pan drops and filter/fluid changes. Fluid is full and clean.
It shows no codes when I cycle the ignition on and off 2x. Occationally I will get a check engine light with no code, after tightening the gas cap the light will go away after a couple days.
It seems odd how this will happen from time to time with no real reason or other problems.
