New badges finally came in
and Borla cat back exhaust, airaid cold air intake and throttle body spacer and full HIDs installed yesterday :smiley_thumbs_up:
also removed that pillar tape , looks way better
What HID kit did you get and where did you get it from? I've been looking around but the bulb size for these are apparently brand new and not very easy to find.
Low Beams are HIR2 or 9012 and I believe the High beams are 9006. From everyone I've spoken with, you'll want to stay away from doing the High Beams as there is warm up time and you can't really use the flash to pass feature.
Im not 100 percent sure what kind
Had them installed at a local shop in edmonton
The brand is beamers I think but I don't know the size
I'll see if I can find some info
Does your Borla exhaust drone at all? I had the mopar performance exhaust installed. Overall I love the sound. The only issue I'm having right now is that it drones big time when cruising around 70-75mph (around 2200 rpm). Still trying to figure out a solution. I may just replace the whole thing instead of chopping it up and trying to fit other mods in there to stop the drone.
Related Threads
DODGE RAM FORUM
2.2M posts
201.9K members
Since 2008
