About 1 out of 20 times I start my truck; the check gauges light comes on and the oil pressure gauge shows 0 oil pressure. There's definitely oil circulating in the engine and I think its a gauge or sensor failure. If shot the truck off it comes right on and everything is fine; anybody have this problem and how did you fix it?
Wow I just re-read my post and need to correct it a bit...
About 1 out of 20 times I start my truck; the check gauges light comes on and the oil pressure gauge shows 0 oil pressure. There's definitely oil circulating in the engine and I think its a gauge or sensor failure. If I shut off the truck and turn it back on the gauge comes on and everything is fine; anybody have this problem and how did you fix it?
