Is there any benefit to having the correct tire size calibrated to the truck from a performance standpoint?
I understand that it makes the speedometer accurate, but does it affect anything else?
Having it say 10% out (Where the speedo reads 90k/hr when you're really traveling 100k/hr cuts the odometer down the same 10%....
Its easy enough to compensate for when reading the speedo, and keeps recorded miles on the odometer lower....any other factors to consider?
