DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum (http://www.ramforumz.com/index.php)
-   Dodge Ram Knowledge Base (http://www.ramforumz.com/forumdisplay.php?f=41)
-   -   3rd brake light leak fix (http://www.ramforumz.com/showthread.php?t=87346)
snrusnak 07-17-2011 08:13 PM
5 Attachment(s)
Just thought I'd post this up for what I did to solve my problem of the 3rd brake light leaking. I was getting water in both rear top corners of the cab where the headliner meets the plasic and rear window glass. What happens is the water leaks through the seal of the light, then makes it's way into the cab sheet metal, and runs to both corners due to the way the metal slopes. If you have water dripping from the top corners of the rear of the cab it is probably the 3rd brake light seal leaking. First thing I did was check to make sure the window seal also was not leaking, by pouring water in the open channel (once you remove the two screws holding on the light and pull the light off). There are weeps that let the water drain at the bottom of each corner of the window, my passenger side weep is wide open, the driver side weep is a little tighter (due to the window being installed slightly crooked), but it lets the water out fine. So anyway I then cleaned the sand/muck off where the light seals, and cleaned the old gasket off the light (very easy with flathead screwdriver, then again with adhesive remover). I then applied new thicker gasket (not a foam type like the original), I bought it at home depot, it is slightly wider, and about twice as think, but still very compressible. This is more rubber like (EPDM) than foam like, so should seal better. It doesn't turn sharp corners well, so I cut about half way through for the top two bends, and cut a separate strip for the bottom, this way the bottom corners are open and will let any water that may get in drain out. Pics....
snrusnak 07-17-2011 08:16 PM
More pictures....
snrusnak 07-17-2011 08:19 PM
Don't know why that didn't work.... Will post remaining pics later it won't let me post anymore pics, I gotta go help with dinner, be back later :4-dontknow:
snrusnak 07-18-2011 12:49 AM
Hmmm....maybe a moderator can help me? I'd love to post the rest of these pictures as maybe they could help someone, but it won't let me attach anymore. It says "you have exceeded your quota"...?
RedRam10 07-18-2011 12:54 AM
Try posting them on photobucket and then post a link to them here. :smileup:
snrusnak 07-18-2011 09:33 PM
Thanks redram, I'm going to give it one more shot...lol!
Here's a step by step on how I fixed my 3rd brake light leak issue...I had water coming in both corners of the rear of the cab, at the very corners of the headliner.
Remove screws from brake light, then remove lens (may have to pull pretty hard, I did). After lens is removed unclip wire harness (squeeze the clip on the connecter and it will release):
http://i1133.photobucket.com/albums/...7-17112312.jpg
I tested to make sure the water that gets in between the front window "seal" and the rear actual window seal drains out the weeps (weeps are at bottom corners of the back glass):
Pouring water into the track:
http://i1133.photobucket.com/albums/...7-17112806.jpg
Water coming out of the weeps:
http://i1133.photobucket.com/albums/...7-17112841.jpg
http://i1133.photobucket.com/albums/...7-17114155.jpg
http://i1133.photobucket.com/albums/...7-17113513.jpg
Next clean the surface of the cab (mine was dirty with water/muck/sand that leaked in. Then you can scrape the old gasket off the light lens (comes off easy with a flat head screwdriver). After I got the majority of the gasket scraped off, I used some adhesive remover and scraped the film that was left behind off (this was a pain and a mess and probably not necessarily):
http://i1133.photobucket.com/albums/...7-17112549.jpg
http://i1133.photobucket.com/albums/...7-17114714.jpg
http://i1133.photobucket.com/albums/...7-17115804.jpg
http://i1133.photobucket.com/albums/...7-17115850.jpg
After the lens surface was clean I applied the new gasket. I bought this at home depot, I chose it because it is slightly wider than the original, and about twice as thick, but still very compressible. It is also more rubber like than foam like, so should seal better. It does not turn sharp corners well, so I cut about half way through at the top corners to turn the corners, but the outer edge is still seamless. I make the bottom a separate piece and left the bottom corners open so if any water gets in it can drain out:
http://i1133.photobucket.com/albums/...7-17121307.jpg
http://i1133.photobucket.com/albums/...7-17121327.jpg
http://i1133.photobucket.com/albums/...7-17121342.jpg
http://i1133.photobucket.com/albums/...7-17122421.jpg
http://i1133.photobucket.com/albums/...7-17122409.jpg
Reinstall once done, it will not sit as tight as before (due to thicker gasket), but will seal. I'm guessing after a few months I will be able to tighten the screws another turn after the gasket gets "precompressed":
http://i1133.photobucket.com/albums/...7-17124239.jpg
http://i1133.photobucket.com/albums/...7-17124250.jpg
Did the hose test for above 5 minutes, not a drop in the cab. Still pending a heavy rain test. Will post back after it rains hard. This all took me about 30-45 minutes working slow. Hope this helps someone...
snrusnak 07-21-2011 10:40 PM
It just poured really hard for over an hour, and as soon as it stopped I went to look at the truck, no sign of any water intrusion. Happy :)
TheAverageJoe 09-09-2011 11:14 PM
THIS REALLY WORKS!
I have a 2006 Dodge Ram SLT Quad Cab.
I did the same thing snrusnak did, per his instructions in this thread.
Home Depot sells a Frost King door seal that is 5/16"x9/16" and is made of rubber, not the spongey material that is supplied by Dodge.
My factory gasket was in fairly good shape by appearance, but was failing due to the material being porous.
My 3rd light, now fits snugger and won't leak after 5 years from the assembly line.
I highly recommend repairing your 3rd light this way if you're having the same problem....
RedRam10 09-09-2011 11:25 PM
Great post, gonna get some for my fix ASAP! Wife complains of the musty smell after the rain pours in!
snrusnak 09-10-2011 01:16 AM
THIS REALLY WORKS!
Glad it helped you :) It's been a while now and still not a drop in my cab :)
Good luck (this is probably the best mod I've done lol as it keeps my truck from stinking!)
